Sagging A*se
stevesims
Sagging A*se
Post by stevesims » Sun Nov 01, 2015 10:59 am
A problem with trailing with extra weight on the boot lid and carrying bottle jacks,tools and other heavy kit in the boot is that the rear armature slowly sags.
This makes the doors hard to open and the soft top struggles to clip onto the windscreen top.
I had a tow bar on a donor car I bought so by fitting this to the SST (T for trials ) and making some bracing using metal box section I hope I have found a solution to this problem.
Has thanked: 167 times
Been thanked: 1175 times
Re: Sagging A*se
Post by scimjim » Sun Nov 01, 2015 12:10 pm
A bit of extra weight over the rear wheels won't hurt in trialling - you could have just tacked some thick walked square section inside the existing U section though?
stevesims
Re: Sagging A*se
Post by stevesims » Sun Nov 01, 2015 12:26 pm
Slowly getting there in the best ground clearance and road manners.
Has thanked: 533 times
Re: Sagging A*se
Post by CNHSS1 » Sun Nov 01, 2015 12:47 pm
Could you fit a petty bar from roll over par to passenger side tunnel to brace chassis? I had one on my ex Nigel Reeves racer (before MSA reg changes to full cage). Stopped chassis flexing fore and aft and stopped altering the door shut apertures
Have some pics on old pc if you need them
stevesims
Re: Sagging A*se
Post by stevesims » Sun Nov 01, 2015 12:54 pm
I have seen that on other cars, my concern is that we don't wear skid lids and I don't want to much metal in the car that we can bang onto.
My next idea is to weld a box section bar between the A pillar to the B pillar ,the door cards will have to come out though.
Has anyone got any tips on mouthing a hydrolic hand brake?
Re: Sagging A*se
Post by CNHSS1 » Sun Nov 01, 2015 1:36 pm
Ah good point. On my original ss1 cvh racer i fitted door bars between A & B pillars, reduced flex no end before i had full cage
alan.wells
Re: Sagging A*se
Post by alan.wells » Sun Nov 01, 2015 4:27 pm
Steve,
You don't want more braking, you've got to get up them there hills :lol:
Alan
Sabre MK2 2Ltr Zetec
Motorhome
1926 Bullnose Morris
3/4 coupe with dicky
A Run around Jazz
M/N 5637
stevesims
Re: Sagging A*se
Post by stevesims » Sun Nov 01, 2015 4:34 pm
Allan
We all entered in Exeter for 2016, are you?
And yes I will sign on. :lol:
Return to “General Trialling Chat”
