another SE5a parts wanted
Locked
jon831
Post by jon831 » Fri Aug 09, 2019 2:25 pm
Hi, I am trying to get my SE5a on the road and need a few parts, if anybody can help it would be appreciated. I will be going to Scimfest on either Sat or Sun.
The parts I need are headlamps, fuel tank sender unit, tailgate gas struts, S/S bottom coolant pipe, clutch pedal return spring.
Thanks Jon.
Has thanked: 189 times
Been thanked: 1277 times
Post by scimjim » Fri Aug 09, 2019 3:16 pm
Welcome to the forum Jon.
You’ll find all of those parts at Curborough :D
jon831
Post by jon831 » Fri Aug 09, 2019 6:11 pm
Thanks Jim, I am looking forward to my first visit to Scimfest and will keep my eyes peeled for parts when I get down there.
scimitar.rog
Post by scimitar.rog » Sat Aug 10, 2019 11:34 am
If Not available with auto jumblers' you have ORG and Graham Walker on site,
jon831
Post by jon831 » Sun Aug 11, 2019 4:52 pm
Thanks rog, I will visit those stands as my list is growing. I now need a brake light switch and a brake master cylinder as well. Also I have just found out why the paint on the body around the rear hatch is rubbed through, one hinge pin is snapped and it looks a pig to repair and possibly can't be done without cutting the fibreglass to get to the pin housing. Ideas from people who have already tackled this would be most appreciated. It's a 1975 car and the pin only seems to be supported on one side of the hinge bracket. The rest of the pin is seized in the bit that is glassed into the body.
Post by Roger Pennington » Thu Aug 15, 2019 9:05 am
I think you may have misunderstood how it works - the pin is welded into the bit that is glassed into the roof, and the hatch hinges rotate on the static pin. (unless they seize, which may cause it to snap off). A search on the forum will reveal more - try Geoff's project thread on SAR, I think he had to deal with it?
jon831
Post by jon831 » Thu Aug 15, 2019 9:14 am
Yes the pin has seized in the hinge and snapped off. Thanks for suggesting Rogers thread I will look at that to see how he solved the problem. Initially I am thinking of make a second bracket to glass in so the hinge is supported on both sides. The awkward bit will be glassing it in so the hinge/tailgate lines up properly, it might not be achievable.
Locked
