coupe rear axle
Has thanked: 81 times
Been thanked: 213 times
coupe rear axle
Post by gtcse8 » Thu Aug 29, 2019 10:19 pm
Phil
So the problem is noise/wear within your axle. :shock:
It may just be wear in the bearings in the diff, OR wheel bearings.
Most of the noise can be removed with replacement bearings and correct re setting of the crown and pinnion.
Have you checked the welds on the torque tubes and centre casting, because IF the welds have failed/or failing then it needs addressing PDQ. :w
philynnbob
Has thanked: 75 times
Been thanked: 22 times
coupe rear axle
Post by philynnbob » Fri Aug 30, 2019 9:57 am
Yes as already alluded to, straight 6 axle is a different length to V6 axle ( coupe)
Phil
guybetts
coupe rear axle
Post by guybetts » Fri Aug 30, 2019 7:17 pm
I've got the original S6 axle (damaged, and I assume not changed before I got the car in 1988) and the replacement axle from a V6. They are both the same length.
However, my S6 is a late car and as already mentioned over the years, has lots of V6 features both in chassis and suspension :shock:
Probably not the best example to suggest a comparison :roll:
GTC Registrar
april2colin
coupe rear axle
Post by april2colin » Fri Aug 30, 2019 8:43 pm
Hi guys. What have I done ? All I want is an axle. Tee Hee.Could do to get it sorted before the NEC. Cheers Phil D.
april2colin
coupe rear axle
Post by april2colin » Fri Aug 30, 2019 8:51 pm
Hi guys. Sorry I missed that reply. I'll check it out next week. Cheers Phil D.
Been thanked: 123 times
coupe rear axle
Post by ScimmyMike » Mon Sep 02, 2019 2:50 pm
Phil, QRG were advertising a few Coupe rear axles on Facebook last week, may be worth ringing Nigel to discuss.
april2colin
coupe rear axle
Post by april2colin » Tue Sep 03, 2019 8:31 pm
Hi guys. Thanks for that. I'll give Nige a bell and see wot he has. Cheers Phil D.
april2colin
coupe rear axle
Post by april2colin » Tue Sep 17, 2019 7:45 pm
Hi guys. So the decision has been made (forced) The axle is coming out and going to a specialist in Preston who says he can turn it around in 2 to 3 days. I'll have another chat with him. But I did manage to win a rev counter on e-bay. I'll let you know. Cheers Phil D.
Has thanked: 32 times
Been thanked: 134 times
coupe rear axle
Post by Coupe Racing » Tue Sep 17, 2019 8:09 pm
If its a 7HA I hope you have a firm quote and know what you are getting for your money as the parts are expensive
april2colin
coupe rear axle
Post by april2colin » Sat Oct 05, 2019 8:32 pm
Thanks but I have no choice. Axle coming out on Tuesday Don;t really want to drive her at the moment. In for a penny.... Cheers Phil D.
april2colin
coupe rear axle
Post by april2colin » Thu Oct 10, 2019 8:32 pm
Hi guys. Here's a question. Is the 7HA the same as fitted to the Daimler Dart ? If so I can get a new crownwheel and pinion same ratio. Cheers Phil D.
windy
Been thanked: 41 times
coupe rear axle
Post by windy » Thu Oct 10, 2019 8:38 pm
Very likely. Also used on lots of old Morgans so there is a good choice of crownwheel & pinion ratios, but plenty £££
Locked
