What engine do I have?
Stoddy
Post by Stoddy » Thu Apr 25, 2019 9:55 pm
I've recently purchased a 72 5a. The engine number is different from that show on the vin plate. The number is C5977. Any ideas what this has come out of and what year it might be?
Thanks Alan
TrevorG
Has thanked: 17 times
Been thanked: 20 times
What engine do have?
Post by TrevorG » Thu Apr 25, 2019 10:50 pm
Could be cs, therefore out of a ford from 82
Has thanked: 144 times
Been thanked: 525 times
Post by Roger Pennington » Fri Apr 26, 2019 12:56 am
I thought Fords normally had 5 numerics after the 2 char date code, so that seems a little unlikely?
Stoddy
Post by Stoddy » Fri Apr 26, 2019 9:06 pm
I was speaking to the chap from Essex engines while ordering a new timing gears and gaskets. He advise that the ford engines had 5 digit engine numbers . The number on my engine definitely starts with the letter C. Thanks for changing the heading!
Thanks Alan
Has thanked: 136 times
Been thanked: 967 times
Post by scimjim » Fri Apr 26, 2019 9:39 pm
Reliant stamped their own engines - are you sure there’s not a faint S before the C?
Stoddy
Post by Stoddy » Thu May 09, 2019 9:15 pm
After a successful evening where I made some progress with my timing gear change I decided to have a closer look at the engine number with better light. Sure enough there's a tiny s infront of the C, so my number is SC5977, so a Scimitar engine but out of a later car. There's also the numbers 3C1 stampted in front of the S.
Thanks for your help.
Alan
Post by scimjim » Thu May 09, 2019 9:50 pm
SC5977 would be in an early 73 car if they were all sequential - there are several that are slightly out of phase, is your car early or late 72?
Stoddy
Post by Stoddy » Thu May 09, 2019 10:37 pm
That ties in Jim. The car was registered 1st of September 1972 however the vin plate and registration document quote and engine number SC4454. That's why I assumed SC5977 is a later engine.
