Stupid question time
Has thanked: 154 times
Been thanked: 1051 times
Re: Stupid question time
Post by scimjim » Mon Apr 06, 2015 3:13 pm
Much of it's covered in the owners manual. If you disconnect the cable from the bonnet release mechanism under the slam panel it will be easy to see if it's the cable or the mechanism at fault. General purpose grease on the mechanism and return spring, if the cable's corroded internally I'd remove it (tie a bit of string to it first :)) and try soaking it in oil or penetrating fluid. I'm not sure if they're still available new.
Post by toomanysabres » Mon Apr 06, 2015 6:15 pm
Been thanked: 561 times
Post by Roger Pennington » Mon Apr 06, 2015 10:47 pm
If it's the cable that's corroded, then there do seem to be generic ones still available which may be suitable? e.g. here and here :)
Crowther
Has thanked: 72 times
Post by Crowther » Thu Apr 09, 2015 12:19 am
The Wurzels! I'll add that to my approved playlist for in the Scim. Pre-'72 music only. An odd rule as I am a child of the 80s...
Been thanked: 70 times
Post by Scimher » Thu Apr 09, 2015 12:42 pm
...Brilliant! Hadn't heard that rather 'subdued' version before. Ah, the late great Adge Cutler................
normnod
Post by normnod » Thu Apr 09, 2015 1:56 pm
Mine had got stiff at the bonnet end, squirted some GT85 up the end in situ and it was sorted.
drcdb15
Has thanked: 32 times
Been thanked: 29 times
Post by drcdb15 » Mon May 11, 2015 8:42 pm
normnod wrote:Mine had got stiff at the bonnet end, squirted some GT85 up the end in situ and it was sorted.
Is that a fix to the problem, or a line from another Wurzels song ... ?? :lol:
Chris
Has thanked: 50 times
Been thanked: 259 times
Post by AJL Electronics » Mon May 11, 2015 9:47 pm
Or something in a defence statement? ;-)
drcdb15
Post by drcdb15 » Tue May 12, 2015 4:49 pm
Actually, to be serious for a moment...
I've had the bonnet release seize on both an Espace (garage released it from underneath, and showed me how) and on my X-type - I did a detailed assessment of that you can read on the Jag forums. With the right set up and the right bits from the socket set, it was a doddle I repeated many times.
But looking at the Scimitar.... er, if the bonnet release *does* break or seize... how exactly do you get in to release the catch? I can't see any way from the top or below without taking a hacksaw to the bodywork/bonnet... is there some way in past the headlamps?
Chris
Post by scimjim » Tue May 12, 2015 4:53 pm
Yes, inner headlamp and bowl out.
Has thanked: 65 times
Been thanked: 96 times
Post by Oldconn » Tue May 12, 2015 5:30 pm
If its a new cable you need, you can try Teleflex or Morse cables from marine chandlers. Morse make "stop" cables in various lengths, complete with "T" handle and threaded collar with nuts . Not the cheapest solution, but very effective.
toolmanchris
Post by toolmanchris » Tue May 12, 2015 5:43 pm
I think I brought something like this for mine and cut it to size
http://www.ebay.co.uk/itm/60-1-5m-T-bar ... 5ae2d8b38e
Chris Barker
http://www.toolmanweb.com
RSSOC: 4125
Seat Leon FR - daily driver
