Ben's (an emotional quandry) 1975 SE5a
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Fri Dec 07, 2018 9:13 am
Doesn’t sound like a PRV problem but you can push the spring when the sump is off to check it’s moving smoothly.
What spec is the running in oil? It comes in various viscosities.
Has thanked: 50 times
Been thanked: 259 times
Post by AJL Electronics » Fri Dec 07, 2018 9:49 am
A quick and easy test is to replace the oil filter. Might save all that work! If not, you have a spare ready primed for next time.
Been thanked: 70 times
Post by Old and Slow » Fri Dec 07, 2018 10:38 am
The only time something similar happened to me was when they rebuilt the crank (reground 30 thou undersize) and fitted standard shells. Hope it isn't this.
roymck
Has thanked: 15 times
Been thanked: 24 times
Post by roymck » Fri Dec 07, 2018 1:05 pm
Some engines have oversized main bearings housings by 15 thou line bored by Ford to reclaim blocks that might otherwise have been scrapped . These need special main bearing shells to fit the oversized block, fit a standard shell you will have problems.
Hope that’s not your problem ?
scmarf
Post by scmarf » Mon Dec 10, 2018 1:49 pm
Update:
Dropped sump and swapped oil pump for old one ; no change.
Dropped sump again and fitted new oil pump back in and filled with 20/50 : marginal increase but still down to about 10psi at 2500rpm hot.
To do:
1) swap oil filter
2) swap oil gauge
3) plastigage on bearings (not sure if it works on main bearings in situ as the crankshaft would be constrained by its own weight plus external loads)
Didn't notice any clearances when assembling crank.
What am I missing?
Ford Fiesta
Post by scimjim » Mon Dec 10, 2018 1:51 pm
Swap gauge just to check? It’s low across the whole range, so it may possibly be the gauge.
scmarf
Post by scmarf » Mon Dec 10, 2018 3:49 pm
Just swapped gauge and hose (admittedly for another old gauge) - no difference.
Just swapped filter - no difference.
Next, swap gauge from the one out of the 6a.
After that, :?:
Ford Fiesta
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Mon Dec 10, 2018 3:51 pm
How did the pickup look? Any signs of a hairline crack (normally where the bracket is)?
Chances of 2 gauges being equally duff is very slim to be honest.
Has thanked: 24 times
Been thanked: 105 times
Post by Coupe Racing » Mon Dec 10, 2018 4:06 pm
Have you replaced the camshaft bearings
scmarf
Post by scmarf » Mon Dec 10, 2018 4:35 pm
Couldn't see any problems and I looked pretty closely.
No. Original camshaft re-ground so assumed not a problem. :?:
Ford Fiesta
Post by Coupe Racing » Mon Dec 10, 2018 5:02 pm
Is the block flat where the pump is mounted
I'm with some others ref the pick up pipe leaking
scmarf
Post by scmarf » Mon Dec 10, 2018 6:56 pm
Yes.
I can only say I gave the pick-up a thorough examination on initial fitting and again on Friday before re-fitting the third time.
Tomorrow I will drop the sump for the third time and check bearing sizes. Those are the only things that have been changed and not checked now. Although I trust my engine man, I really don't know what else to check now.
Ford Fiesta
Post by Coupe Racing » Mon Dec 10, 2018 7:46 pm
Taken from the manual , might be worth a read
Oil flow
Post by Coupe Racing » Mon Dec 10, 2018 7:48 pm
Part 1
First part
Post by Coupe Racing » Mon Dec 10, 2018 7:49 pm
Part 2
Second part
