Sprint Car Head Gasket???
PeterSM
Been thanked: 34 times
Post by PeterSM » Thu Aug 15, 2019 12:38 pm
I have just been checking my sprint car over ready for Sunday and discovered an issue. When I removed the dipstick it was covered with classic brown mayo. So I removed the rocker cover cap and checked that:
Siphoned some water out of the header tank and it looks like this:
Which leads me to think it is a head gasket issue but the compression test gives.
Cylinder PSI
1 135
2 130
3 140
4 160
Which seems OK.
Any thoughts?
I have now also pressurised the cooling system via the expansion tank cap to 15psi and it has held this pressure for over 8 minutes.
Peter Smith
SS1 Sprint Car, 1800Ti SS1 and a very special Sabre DET
tony1966
Post by tony1966 » Thu Aug 15, 2019 1:07 pm
do you have an oil cooler which is water cooled ? could be that if you have
on a static test any hg leaks might not show-but when warm and thousands of rpm with high cylinder pressures it may be passing
PeterSM
Post by PeterSM » Thu Aug 15, 2019 1:23 pm
Thanks Tony. Yes Craig thought it might be the water cooled oil cooler. Guess I will have to try substitution to see if it is that.
Peter Smith
Dcrosby13
Has thanked: 41 times
Been thanked: 130 times
Post by Dcrosby13 » Thu Aug 15, 2019 1:27 pm
I have a good spare cooler Peter and I recently replaced mine in situ but swore I'd never do it in the car again 😬 we can give it a go though!
I break stuff...... :w
PeterSM
Post by PeterSM » Thu Aug 15, 2019 1:32 pm
If you can bring it to Curbs and give me a hand fitting I would be very grateful. It looks pretty inaccessible!
Peter Smith
Has thanked: 568 times
Been thanked: 494 times
Post by CNHSS1 » Thu Aug 15, 2019 2:49 pm
Get the car to Curbs and the compie collective will have it repaired I'm sure 8)
Dcrosby13
Post by Dcrosby13 » Thu Aug 15, 2019 2:51 pm
Thats putting it mildly :lol: I think this time I will remove the engine mount first
PeterSM
Post by PeterSM » Thu Aug 15, 2019 2:52 pm
Its on the trailer plus my canopy to work under!
If it was the water oil cooler wouldn't the pressurising of the water system leak down?
Peter Smith
Dcrosby13
Post by Dcrosby13 » Thu Aug 15, 2019 2:55 pm
we could do with a gasket or atleast some hi temperature silicone if you could bring that along with a socket set?
Dcrosby13
Post by Dcrosby13 » Thu Aug 15, 2019 2:57 pm
I would have thought so tbh, it could still be the headgasket, it might just have gone between a water way and an oil gallery and not the flame ring which would mean your compression would be unaffected, I would swap the headgasket first...
Dcrosby13
Post by Dcrosby13 » Thu Aug 15, 2019 3:06 pm
and be a very small slow leak that might have been going on for a while
Been thanked: 71 times
Post by Nick » Thu Aug 15, 2019 3:07 pm
Bypass oil cooler, change oil, filter and water
Has thanked: 280 times
Been thanked: 155 times
Post by efi_sprintgte » Thu Aug 15, 2019 3:32 pm
Agreed
PeterSM
Post by PeterSM » Thu Aug 15, 2019 3:39 pm
OK I can understand blanking off or joining the water pipes but what do you do about the oil cooler side?
Peter Smith
Dcrosby13
Post by Dcrosby13 » Thu Aug 15, 2019 4:05 pm
good luck with that, those hoses are about the most difficult bit to get to although your inlet manifold is different than mine
