wiper failure...
Trampintransit
wiper failure...
Post by Trampintransit » Mon Aug 12, 2019 2:58 pm
Suddenly the wipers have stopped (6b) . BUT....moving the switch produces a click from behind the centre console somewhere? Is that wherethe 'control unit' as it appears on the wiring diagram lives? If the control box, which I'm ASSUMING is some kind of solenoid is firing then the wiring from it to the motor..or the motor is screwed ..is that reasonable thinking?
spegru
wiper failure...
Post by spegru » Mon Aug 12, 2019 3:16 pm
Hi. I think the click you heard is from the intermittent wipe controller. That unit works by giving the main motor a prod so that the wiper park mechanism takes over and causes the motor to give a complete sweep.
Unfortunately it sound unlikely that that unit is to blame. More likely a fuse or a poor earth I would think
Been thanked: 842 times
wiper failure...
Post by philhoward » Mon Aug 12, 2019 3:24 pm
If you suspect the 6DA control unit, it has two plugs (one from the loom, one from the switch) which you can join together to bypass it.
Dennis Nicholas
Has thanked: 64 times
Been thanked: 37 times
wiper failure...
Post by Dennis Nicholas » Tue Aug 13, 2019 8:06 am
Suspect the plunger switch on the motor. Somewhere on this site there are detailed descriptions of the motor, how it works and how to replace the old obsolete plunger switch with a new one.
Dennis
Dennis Nicholas(RSSOC)
wiper failure...
Post by Roger Pennington » Tue Aug 13, 2019 10:58 pm
Try this "How To Guide"?
