Mechanical fuel pump problem - Essex engine.
Has thanked: 50 times
Been thanked: 259 times
Post by AJL Electronics » Sun Aug 11, 2019 4:23 pm
Got a strange one...
The standard mechanical fuel pump was removed from a known good engine and used in one that I have just replaced the cam in. Initially (as per the original fit) I had no insulator gasket fitted and got no fuel delivery. I took it out and operated the lever a couple of times and got good delivery. I put it back with an insulation spacer and still no operation. I was careful to get the lever upwards during fitting.
The cam was refitted correctly with the fuel pump eccentric mounted!
Anything obvious I am missing?
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Sun Aug 11, 2019 4:28 pm
They can be sensitive to insulation spacer thickness.
scimitargtc
Been thanked: 22 times
Post by scimitargtc » Sun Aug 11, 2019 7:50 pm
Got a spare generic elec pump you can have at Curborough (Saturday) if you want it
Been thanked: 385 times
Post by peter freeman » Sun Aug 11, 2019 9:49 pm
The fuel pumps come with a variety of arm lengths - sounds like yours is too short
IanC
Post by IanC » Mon Aug 12, 2019 9:15 am
I just measured the length of the arm on a known working one, and it's 11cm long
fuel pump
Current : SE5a 4spd auto
Rev Light
Been thanked: 30 times
Post by Rev Light » Mon Aug 12, 2019 9:36 am
The other thing about that type of fuel pump is that if the engine is fitted with an alloy timing wheel, it can touch. Making an awful racket. I changed mine to a fule pump with a slimmer cast leg. Which has been working fine.
SE5a 'Fancier'
JoeySully
Been thanked: 32 times
Post by JoeySully » Mon Aug 12, 2019 10:04 am
VERY NOISY !! When I fitted mine i thought ohh people do say the steel timing gears are noisy.
Post by AJL Electronics » Mon Aug 12, 2019 11:21 am
Got it sorted. No matter what I did, there was no pumping so resorted to filling the float bowl, starting the engine and feeling for the cam eccentric with the pump lever. Once the pump was bobbing away I nipped it up with the thin gasket. Never had one play me up like that before and I have done a lot!
scimitargtc
Post by scimitargtc » Mon Aug 12, 2019 11:24 am
Glad you got it done I’d had exactly the same issue a couple of months ago but chickened out and put a facet pump and filter king on plus a proper blanking plate (all from burtons)
