Electrickery question
Gillsfan
Been thanked: 25 times
Post by Gillsfan » Thu Aug 08, 2019 3:46 pm
So I'm in the middle of rewiring the front of Rat Rod, headlights, indicators, horn, fan, air horn inclusive of fitting relays. Now all seemed to be going well, I was testing the new wiring and....... The indicators have stopped working. When I first tried the voltage stabalizer clicked like a flasher unit now it doesn't, only 6 volts at the flasher unit. The battery is fully charged. I've barely touched the indicator wiring and I haven't touched the rear indicator wiring at all. Any ideas????
1969 SE 5 Manual O/D Rat Rod
Has thanked: 58 times
Been thanked: 624 times
Post by philhoward » Thu Aug 08, 2019 3:50 pm
6 volts with respect to battery negative, or a piece of metalwork? What voltage do you have on the ignition supply fuse in the fusebox (both sides of the fuse)?
Gillsfan
Post by Gillsfan » Thu Aug 08, 2019 4:05 pm
Phil I used the earthing point behind the dash. I've popped out, so I'll have to check the fuse when I get back.
Post by philhoward » Thu Aug 08, 2019 4:08 pm
Not "that" earthing point?...
Gillsfan
Post by Gillsfan » Thu Aug 08, 2019 4:13 pm
Phil It has an extra, heavy duty earth cable from 'that' earthing point direct to the chassis. I've been adding earths all over the car, some of my earths have earths.
Gillsfan
Post by Gillsfan » Thu Aug 08, 2019 5:01 pm
Fixed it self. Battery charger has been on since I went out and I'm assuming low battery because it all works as it should and I now get 12 volts at the flasher unit. My battery charger had a light on saying charged and maintaining which is why I assumed it was charged.
Phil the resistance between "that" earth and the battery is 0.5 Omps, are you happy with that :D
Been thanked: 240 times
Post by AJL Electronics » Thu Aug 08, 2019 5:41 pm
He probably would be if any of us knew what that meant. :mrgreen:
TrevorG
Has thanked: 23 times
Been thanked: 20 times
Post by TrevorG » Thu Aug 08, 2019 5:53 pm
An omp as an amp as it shorts through your body😁
Gillsfan
Post by Gillsfan » Thu Aug 08, 2019 6:09 pm
So 8/9 years ago Rat Rod suffered complete electrickery failure at curbs. Phil and Jim traced it to a combination of a horrifically wired hazard switch and the earthing point behind the dash on a 5 (dead centre). I'm assuming when Phil says "that" earth, that's what he means.
Post by philhoward » Thu Aug 08, 2019 6:26 pm
Yep - the BDR earth lashed in temporarily during a monsoon at Curborough.
0.5 OHMS is actually quite high but that’s probably the resistance of the leads on your meter ;)
