C3 dipstick tube
ard126k
Been thanked: 37 times
C3 dipstick tube
Post by ard126k » Tue Aug 06, 2019 11:28 am
Hi
I notice that the dipstick tube is loose on the GTC's autobox. Is it just a push fit like the engine one, so a skilful tap will re-seat it?
Alex.
1971 SE5 1977 SE6 1982 GTC
GTC Ian
C3 dipstick tube
Post by GTC Ian » Tue Aug 06, 2019 1:38 pm
there should be an O ring at the top to seal the dipstick in the tube. At least I have one on mine
Members since 1984
Dennis Nicholas
Has thanked: 64 times
C3 dipstick tube
Post by Dennis Nicholas » Mon Aug 12, 2019 9:46 am
Ian.....tube not dipstick loose.
Ard. When my engine dipstick tube was loose (just a push fit) I tried opening out tube but to no avail as I just could not get dia. just right to be a good push fit. In the end I thoroughly cleaned inside the hole, around the engine surface surrounding and the tube and glued it back in. I either used Araldite or JB Weld. One of the many Loctite products may be used instead of glue. There is a small shoulder in the engine hole that the tube sits against so the correct length of tube protrudes from the engine and the dipstick protrudes the correct amount into the engine to give correct oil level. I don't know if gearbox has similar set up.
Stick at it :D
Dennis
Dennis Nicholas(RSSOC)
TrevorG
Has thanked: 35 times
Been thanked: 44 times
C3 dipstick tube
Post by TrevorG » Mon Aug 12, 2019 9:54 am
Hi guys, just had the result of someone aralditing in a dipstick tube. Boy did we have fun removing it so that the engine block would fit past the tool post on the facing machine. When I put it back, I used aero grade loctite. Best to think ahead if the engine ever needs rebuilding😁
Dennis Nicholas
C3 dipstick tube
Post by Dennis Nicholas » Mon Aug 12, 2019 10:44 am
Ah.....how did you manage to remove it in the end??
Dennis
TrevorG
C3 dipstick tube
Post by TrevorG » Mon Aug 12, 2019 1:00 pm
Like everything else that I came upon Dennis 😁.
Try, try again, sweat, curse, walk away, coffee, come back, plead with it, then get the oxy out. Trouble with spot heating a block is....Craaaack!!!
Therefore, I only lightly dusted it and got the block warm - then managed to wiggle the tube free with mole grips over a taped up area so I then put it back with a thread sealant that I know gives way at a low torque as by this time it had worn quite loose.
TrevorG
C3 dipstick tube
Post by TrevorG » Mon Aug 12, 2019 1:05 pm
P.S. I'm only responding now as I'm at the coffee stage on getting the engine off the stand and onto a trolley, ready to mate with the gearbox...progress!
ard126k
C3 dipstick tube
Post by ard126k » Wed Aug 28, 2019 5:41 pm
Just to round this off - I found the looseness was in the stay from the tube to the bellhousing, now tightened. The tube itself is still loose in the box.
Alex.
