shock compatibility se5a/se6 gtc etc
tony1966
Post by tony1966 » Mon Aug 05, 2019 12:37 pm
can any of you kind folk tell me if the later gtc shocks will fit an se5a are they interchangable..i currently have avo on front and what looks like standard rear which one seems to be very damp-and if the springs would sit high-my car is high anyway but i dont want 4x4 height lol
JoeySully
Been thanked: 32 times
Post by JoeySully » Tue Aug 06, 2019 6:46 am
No the shock bushes are different widths.
tony1966
Post by tony1966 » Tue Aug 06, 2019 9:40 am
thanks for reply
Dennis Nicholas
Post by Dennis Nicholas » Thu Aug 08, 2019 12:31 am
but since the GTC are 1 1/8 inch wide and the 5 are 1 1/4 wide a 1/16 inch large outer diameter 1/2 inch inner diameter washer on either side of the bush would be an advantage which would save wear on the brackets inner face and get you to the right width between brackets.
or even drill out bracket holes from 1/2 inch to 5/8 inches and fit the spacers as per the 6 onwards cars (spacers on inside of brackets). Spacers more easily replaced than brackets when worn.
Denis
Dennis Nicholas(RSSOC)
