essex v6
tony1966
essex v6
Post by tony1966 » Tue Jul 30, 2019 10:47 am
Has thanked: 132 times
Been thanked: 875 times
essex v6 heads
Post by philhoward » Tue Jul 30, 2019 11:33 am
If it’s a pre-72(ish) engine, then they have oval inlet ports. 72-on have D shaped inlet ports.
Another one to put in the mix is low and high compression heads - high compression (car) heads only have the recess around the valves and spark plug; low compression (transit/industrial engine) have the recess across pretty much the whole of the bore area.
tony1966
essex v6
Post by tony1966 » Tue Jul 30, 2019 6:18 pm
do
Been thanked: 438 times
essex v6 heads
Post by peter freeman » Tue Jul 30, 2019 8:10 pm
Got mine from a club person ( bought in the the USA ) worth the money no matter what it costs - be sure to blank off the oil drain holes ( with rags works ) just in case you drop a valve retainer etc. Smoke at idle or on start up is a sign that the stem seals need replacing - on overrun piston rings.
tony1966
essex v6 heads
Post by tony1966 » Tue Jul 30, 2019 9:32 pm
thanks for the piccy-there are copies available of the very tool you pictured online,will give one a shot
cheers t
Has thanked: 32 times
Been thanked: 134 times
essex v6 heads
Post by Coupe Racing » Wed Jul 31, 2019 7:00 am
If you do this job in situ then make sure the valve does not drop into the cylinder
Has thanked: 82 times
Been thanked: 216 times
essex v6 heads
Post by gtcse8 » Wed Jul 31, 2019 8:18 am
Feed a lot of string into the cylinder then turn the piston up to stop the valves dropping, then just wind it back down and pull the string out.
Only other way would be to put compressed air into the cylinder.
Both methods work so long as your careful.
essex v6 heads
Post by peter freeman » Wed Jul 31, 2019 8:40 am
My valves just stayed where they were - no need for anything to keep them up but I did make sure the pistons were up so if they did drop it was not far and they could be pulled back easily
tony1966
essex v6
Post by tony1966 » Wed Jul 31, 2019 10:49 am
i h
