se5a steel wheels with trims
tony1966
Post by tony1966 » Sat Jul 27, 2019 2:51 pm
i got a spare set 5 original steelies with composite wheel trims with my se5a[car is presently fitted with slot mags]
does anybody know what size they are -i have to use one as a spare for underbonnet as the spare mag wheel is too big-and what spare tyre size is normally fitted
thanks [again] in advance :D
tony1966
Post by tony1966 » Tue Jul 30, 2019 1:08 pm
Has thanked: 178 times
Been thanked: 1230 times
Post by scimjim » Tue Jul 30, 2019 2:02 pm
Standard steels are 5.5Jx14.
Scimitar Wolfrace are 6Jx14.
Standard tyres on both were 185 wide, 80 profile - these are difficult to find at a decent price now, so most go for 195 or 205 and a 75/70 profile.
You probably realise but Wolfrace and steel wheels need different nuts.
The Wolfrace should fit under the bonnet unless you have wider tyres - you can take a little off the lip of e bonnet slam panel to give a bit more clearance?
tony1966
Post by tony1966 » Tue Jul 30, 2019 4:15 pm
thanks for reply car has slots-wolfrace type but not genuine "woolfies" there is a set 5 -all fitted with 205/70/14 sadly,it would have been good if they were 185-say 70 or 80 profile -but they are all new tyres so i would be reluctant to switch them-if the steels are 14" i will just get a skinny tyre fitted to one for underbonnet-aka spacesaver
yes-noticed the nuts-got a different set with the steel wheels
Post by scimjim » Tue Jul 30, 2019 6:40 pm
Cobras? They look good :D
Post by Roger Pennington » Tue Jul 30, 2019 6:55 pm
Cobras would be my first guess too - they're certainly shiny :D
tony1966
Post by tony1966 » Tue Jul 30, 2019 10:06 pm
i dont know the make-will need to check for a makers stamp
wolfrace slots are probably my favourite 70s wheel tbh
Post by scimjim » Tue Jul 30, 2019 10:28 pm
Car looks good too (if a little high), my first 5a was Nevada :D
tony1966
Post by tony1966 » Wed Jul 31, 2019 12:11 pm
low is slow lol,+need the height on out roads-speedbumps etc
