Whiny rear diff - advice needed
pauluspaolo
Post by pauluspaolo » Tue Jul 23, 2019 9:56 am
Hi all,
I took my SS1 out a couple of days ago (my wife & I went to a classic car show at Newby Hall near Ripon - only saw 2 Reliants there & they were 3 wheelers :( ) & the rear diff is very whiny at any sort of reasonable speed. Is this normal - they all do that sir! - or does it indicate that I need a new/reconditioned one?
I have to say that the diff has always been like this & doesn't seem to have got any worse over the years that I've owned the car (10 this year I think). What has got worse is the oil leak from the diff. It's not like the diff is completely draining of oil overnight but it's bad enough that the MOT tester mentioned it & it's certainly becoming noticeable on the garage floor (not that this is a massive concern)! I regularly check the level of the diff oil & top up if needed but it never seems that low to me despite the leak.
Anyone got any advice??
Many thanks :)
Been thanked: 379 times
Post by peter freeman » Tue Jul 23, 2019 10:34 am
Try Molyslip - cannot do any harm even if it does not reduce the noise.
Has thanked: 152 times
Been thanked: 1038 times
Post by scimjim » Tue Jul 23, 2019 11:35 am
They’re fairly bulletproof and under stressed in the small sports and don’t generally make any noises. You can rebuild them, buy a reconditioned item, or just fit a replacement s/h one?
With the zetec you have, I’d go for a 3.62 ratio? I have plenty of s/h 3.92 but think I sold my last 3.62 to Nick Keyser recently.
Has thanked: 100 times
Been thanked: 150 times
Post by reliant-reviver » Tue Jul 23, 2019 1:27 pm
Mine sings a bit at speed and I live with it. It's more noticeable with the hardtop on as this seems to amplify cabin noise.
Any noise from the diff is very apparent in an SS1 due to it being sat just behind the occupants. Later cars / Sabres did feature additional insulation underneath the fuel tank to try and quieten things down.
If the diff whine is really that bad you may as well change it for a good secondhand unit although it's a bit of a faff. However the presence of a whine does not likely mean there is any impending doom. They are strong units and don't really fail.
Has thanked: 282 times
Been thanked: 223 times
Post by Corky » Tue Jul 23, 2019 1:56 pm
I’ve got two 3:62 here if you’re looking to buy one.
Correction, I've got two 3:92 here :oops:
Has thanked: 415 times
Been thanked: 347 times
Post by CNHSS1 » Tue Jul 23, 2019 9:50 pm
Check the diff mount bushes and moutings to chassis. If they are damaged or the chassis plates cracked the diff cradle can actually touch the chassis and it rings like a bell! Changing the diff will not improve things
pauluspaolo
Post by pauluspaolo » Wed Jul 24, 2019 10:45 am
Sorry if it's a dumb question but what would the difference be between a 3.62 diff when compared to the normal (3.92?) diff?
Many thanks :)
Has thanked: 73 times
Been thanked: 678 times
Post by philhoward » Wed Jul 24, 2019 11:02 am
Simple maths - about 7.5% "taller" in each gear. As a result, 5th gear become 22.5mph/1000rpm instead of 21mph/1000rpm, so 70mph is now about 3100rpm instead of about 3350rpm
Post by scimjim » Wed Jul 24, 2019 11:03 am
Lower rpm when cruising, more useful first gear.
Post by peter freeman » Wed Jul 24, 2019 11:04 am
We never use 1st gear
pauluspaolo
Post by pauluspaolo » Wed Jul 24, 2019 2:00 pm
Ta for that & it's food for thought as whilst I do use 1st gear it is pretty much redundant.
Just out of interest Jim how much would you want for a standard 3.92 diff?
Thanks again :)
