SE5A Transmission fluid leak.
Timharwood69
Post by Timharwood69 » Mon Jul 22, 2019 6:54 pm
I have noticed that some fluid is leaking form the auto box on my 1974 5a. I've wiped everything down and i think its coming from the rear oil seal, can this be changed in situ or do I have to take the engine and box out.
Has thanked: 181 times
Been thanked: 34 times
Post by willholderogri » Mon Jul 22, 2019 7:49 pm
If you take the prop shaft off it can be replaced
Timharwood69
Post by Timharwood69 » Mon Jul 22, 2019 8:07 pm
cheers Will
Laters
Has thanked: 50 times
Post by Laters » Mon Jul 22, 2019 9:06 pm
Just had to replace the auto box rear oil seal on my se6. Found one of the propshaft uj's had gone notchy so that got changed at the same time.
Paul
Timharwood69
Post by Timharwood69 » Tue Jul 23, 2019 4:25 pm
Hi Paul how much trouble is it to get the seal out as I have to do mine on the drive outside the house.
Tim
Laters
Post by Laters » Tue Jul 23, 2019 8:56 pm
Hi Tim on mine which is a ford c3 transmission it was a fairly easy.
The seal on mine had a metal lip which I managed to get a chisel under with a little help from a small hammer then used a pry bar and it came out.
Getting the new one in however required a metal tube that sat on the metal part of the seal and tapped it in with a hammer.
Took a few goes to get it in properly but its in now. Fingers crossed it deals with the leak.
Got a small seal to change on the kickdown lever then hopefully it will be a little more oil tight.
All the above was done with the car sat on a set of normal car ramps with the rear wheels & a set of hydraulic lifting ramps under the front wheels while its sat in a single car garage so not a lot of free space.
So much easier when you can get to things though so the hydraulic lifting ramps are worth their weight in gold, why didn't I buy some years ago I will never know.
Paul
Timharwood69
Post by Timharwood69 » Wed Jul 24, 2019 11:03 pm
Paul thanks for the reply I will have a go myself now rather than taking it to the garage.
