Window felt scraper seals SE5 - Parts missing / Wanted ?
1969SE5
Post by 1969SE5 » Mon Jun 24, 2019 12:23 am
Chaps, when I got the car it had SS1 external seals retro fitted, I have bought the seals/strips from QRG but cannot see how to attach them to the doors ? I am assuming I am missing some clips or the like ? Any help would be greatly appreciated.
Has thanked: 79 times
Been thanked: 212 times
Post by gtcse8 » Mon Jun 24, 2019 7:48 am
Dave the felt is glued into a stainless steel pressing that is pop riveted to the door.
Do you have those??.
1969SE5
Post by 1969SE5 » Mon Jun 24, 2019 8:05 am
nope, nothing like that, and not sure if anything to secure anything to :(
anyone got any pics ? bummer as doors all built up.............
Post by gtcse8 » Mon Jun 24, 2019 8:10 am
I can do pics later today, but I know they show up in the factory manual as I have supplied a few over the years.
Don`t think I have any spares left tho
1969SE5
Post by 1969SE5 » Mon Jun 24, 2019 8:29 am
cheers Mark, looks like mine might have had those removed or rotted away ?, not likely that its different being 1st 500 ?
Post by gtcse8 » Mon Jun 24, 2019 8:40 am
In my experience the alloy pop rivets corrode and the SS pressing falls off.
1969SE5
Post by 1969SE5 » Mon Jun 24, 2019 9:02 am
many thanks, interested to see what the channels look like, as can not quite envisage how they will attach to my doors currently....
Has thanked: 178 times
Been thanked: 1227 times
Post by scimjim » Mon Jun 24, 2019 9:06 am
Has thanked: 219 times
Been thanked: 47 times
Post by willholderogri » Mon Jun 24, 2019 9:11 am
I would be interested to see the felt . please see attached pics of the channels I have to fit mine as well. I do have two more somewhere.
windy
Been thanked: 41 times
Post by windy » Mon Jun 24, 2019 9:13 am
The stainless trim was only fitted on the SE5a, not the SE5 as far as I'm aware, and certainly not any of the first 500, although they can be retro-fitted.
On the SE5 the seal can be glued straight to the inside of the opening using a polyurethane sealant.
David Tew
Has thanked: 26 times
Been thanked: 69 times
Post by David Tew » Mon Jun 24, 2019 9:23 am
These are the ones I used. I used Stixall to glue them in place after the door had been rebuilt and my wife sacrificed two clothes pegs as wedges to hold them in place while the adhesive set. :)
I found the original seals in the bottom of the door. They didn't have any holes in them so I presume they were originally glued on (on the Coupe, at least).
Out of interest, Stixall is the stickiest adhesive I have found and it is completely waterproof. The seals won't come off! :wink:
Post by willholderogri » Mon Jun 24, 2019 9:32 am
Where did you get them ? Please
1969SE5
Post by 1969SE5 » Mon Jun 24, 2019 10:12 am
thanks guys...... assume one each side of the glass then, that would make sense......... bit of a relief as could not see how i was going to rivet anything in the room i have available with glass in etc.....
David Tew
Post by David Tew » Mon Jun 24, 2019 10:39 am
I bought them a few years ago and can't remember where from now. Woolies do something similar, though.
I only fitted one on the outside as the inside had a plastic T-shaped trim stuck to the top. I think this is one of the areas where the Coupe differed from the SE5 as Jim's pic clearly shows one each side and my car was completely standard when I got it.
Post by gtcse8 » Mon Jun 24, 2019 1:45 pm
You can just make out the heads of the dissolved alloy pop rivets in the Top SS stamping, that was the Exterior one
And they had another go at fixing the bottom one, as witnessed by the extra holes :roll: which was the Inner fitting.
