Detachable steering wheel
Rattling
Post by Rattling » Thu Jun 06, 2019 4:00 pm
Hi thinking of fitting the above,has anyone already done this ? Also could anyone confirm which steering column is used so I can source the right boss,any help will be very welcome ,thanks .
Colin
1800 Ti
scimmy_man
Been thanked: 35 times
Post by scimmy_man » Thu Jun 06, 2019 4:56 pm
as long as you have an aftermarket boss and wheel you can buy a fitting to go between them
the thinnest is about 20mm
Been thanked: 355 times
Post by peter freeman » Thu Jun 06, 2019 5:38 pm
I could be wrong but I have the feeling that it is a Triumph size boss you need - Spitfire etc
hermeticist
Has thanked: 28 times
Post by hermeticist » Thu Jun 06, 2019 7:02 pm
As far as I can ascertain, it is early Spitfire (not mark V), TR4, Elan etc... I think this is the right one but I haven't tried yet: https://www.ebay.co.uk/itm/LOTUS-ELAN-E ... 2891945431
frodo_monkey
Post by frodo_monkey » Thu Jun 06, 2019 7:22 pm
I have a Mountney boss for an early Spitfire that I bought in error if you’re interested.
Rattling
Post by Rattling » Thu Jun 06, 2019 8:13 pm
Great information many thanks from all above,I just need to decide which wheel and boss to go for then, I'm assuming the cover behind the wheel but not the stalks will need some modification,would I be right ? Going for a flat wheel not dished ,frodo monkey thanks for the offer may well bet back to you on that .
Colin
1800 Ti
hermeticist
Post by hermeticist » Thu Jun 06, 2019 9:40 pm
Looking at the pictures of Momo wheels(?) fitted to Sabres, it looks like the boss is just attached in front of the steering cowl (the plastic part which the stalks exit from). One would think this would make the steering wheel too close, but people don't seem to have a problem...
hermeticist
Post by hermeticist » Thu Jun 06, 2019 9:49 pm
If you can tell, it appears the boss is added to the column
Has thanked: 136 times
Been thanked: 968 times
Post by scimjim » Thu Jun 06, 2019 10:20 pm
I think that the Momo (Corsa type D35) wheel itself is very thin and the boss is about the same thickness as the standard wheel?
type approval requirements:
r12.03 (steering) momo position.pdf
(38.79 KiB) Downloaded 34 times
Has thanked: 343 times
Been thanked: 279 times
Post by CNHSS1 » Thu Jun 06, 2019 11:16 pm
Tony Idle made some super slim wheel adaptors iirc
Rattling
Post by Rattling » Fri Jun 07, 2019 7:15 am
Many thanks for the photo, I suppose when you subtract the depth of the original wheel the difference isn't going to be that much .
Colin
1800 Ti
Rattling
Post by Rattling » Fri Jun 07, 2019 7:17 am
Many thanks Jim
Colin
1800 Ti
Post by CNHSS1 » Fri Jun 07, 2019 11:36 am
Yep agreed Jim
Clueless1
Post by Clueless1 » Fri Jun 07, 2019 7:48 pm
I have a brand new Mountney boss and a new Momo wheel.....didn’t realise that they had different centres! I’m looking for a boss to fit the Momo wheel then the Mountney boss will be for sale, bnib.
Has thanked: 157 times
Post by willholderogri » Sat Jun 08, 2019 8:27 am
I made an adaptor for my mono boss to fit the mountney steering wheel .6mm aluminium plate turned on the lathe .
