Front arb
hermeticist
Has thanked: 35 times
Front arb
Post by hermeticist » Tue May 28, 2019 4:53 pm
At last the top wishbone bolt has given up! So, today I started putting the suspension back together. However, the front ARB to chassis poly bushes seem to be made back to front?!
If you can see from the photos: the old bush has the locator tabs on the opposite side to the poly bushes, I wondered if they were sided but all of my brackets are handed the same (along with the old bush) and the polys are all opposite to that...
Anyone have any ideas?
Has thanked: 101 times
Been thanked: 150 times
Front arb
Post by reliant-reviver » Tue May 28, 2019 5:29 pm
Yep. Superflex list a late and an early Bush. You have the wrong ones evidently!
I think it's actually a red herring as I have only ever come across one type of clamp.
hermeticist
Front arb
Post by hermeticist » Tue May 28, 2019 5:37 pm
Mine are stamped 22mm, which I thought were the later type?
hermeticist
Front arb
Post by hermeticist » Tue May 28, 2019 5:39 pm
I should have said that the brackets are also from late cars... a G reg and an F reg...
Has thanked: 153 times
Been thanked: 1040 times
Front arb
Post by scimjim » Tue May 28, 2019 5:46 pm
They’re all 22mm - I’ve never noticed a difference between early/late cars either - but I’ve probably never looked that closely :D
hermeticist
Front arb
Post by hermeticist » Tue May 28, 2019 6:53 pm
Has anyone noticed that the other Superflex ARB bushes are back to front? The thing is, I can probably fit them but they will be more prone to movement inside the bracket...
hermeticist
Front arb
Post by hermeticist » Tue May 28, 2019 11:17 pm
So, I checked the Superflex website and the bush in the picture is definitely the reverse of my brackets, are there different brackets?
Front arb
Post by reliant-reviver » Wed May 29, 2019 5:40 am
Superflex did manufacture both. Just had a look and all I can see available is the one above under both Reliant and Vauxhall listings.
Something than can likely be resolved but I'm the mean time you are probably as well to just slice off the offending bumps and I doubt the bushes would move in use anyway.
There is only one type of bracket as far as I'm concerned.
Has thanked: 182 times
Been thanked: 98 times
Front arb
Post by efi_sprintgte » Wed May 29, 2019 7:24 am
Or slice the bottom off and turn it round?
Edit- nope, wouldn’t work
dypcdiver
Front arb
Post by dypcdiver » Wed May 29, 2019 10:30 am
Here are the correct ones.
Like you I also have a set of the wrong ones.
My car is a Mk 2 Sabre LHD 1993 registered December.
Some mistakes are too much fun to only make once.
There are times when I think the gene pool could do with some chlorine.
Yellow peril, Sabre Turbo LHD
Previous:- 4 x Coupes. Se5a. Se6. SE6b. 1600 SS1. 1800 Ti. Presently:- Sabre Mk2 Turbo.
Has thanked: 32 times
Been thanked: 50 times
Front arb
Post by Alan SS1 » Wed May 29, 2019 12:42 pm
just cut the offending lumpy bit off, :D the main lump will keep them in place, I've got a block of PU on each side front & rear and NO knobbly bits / ridges as cut from a section of 35mm thick pigging disc (probably 65 or 70 shore hardness)
Front arb
Post by scimjim » Wed May 29, 2019 1:08 pm
2528 is listed by Superflex as the early bush, 1695 as the late (galv chassis) - I think they’re all 2528 but will check my box of arb mounts tomorrow.
Has thanked: 166 times
Been thanked: 556 times
Front arb
Post by Roger Pennington » Wed May 29, 2019 5:03 pm
My spare pair (not yet fitted) which came from Nigel at QRG, are 2528 (supplied for a late galv chassis car)
hermeticist
Front arb
Post by hermeticist » Thu May 30, 2019 9:52 am
Thank you for your replies, I think there is an issue with Superflex and the bushes because I have two sets of supposedly late brackets (both from 1989 cars) and the listed bush does not fit.
I contacted Superflex and received the following email, which might become a bit of an issue - unless, as suggested, we just modify the bushes...
Hi Dom
Yes, there ‘were’ two different types, you have ordered the one for ‘late galvanized chassis’ we used to offer the early non galvanized chassis version – which is the opposite, see here:
https://www.superflex.co.uk/datasheets/spf1695.pdf
but I’m afraid the last of our stock went yesterday & we have decided to discontinue.
hermeticist
Front arb
Post by hermeticist » Thu May 30, 2019 9:59 am
I did manage to buy a set of the "early" bushes but I'm wondering if Superflex have made a mistake and the 1695 part is the non-galvanised type? If they have stopped manufacturing what they think is the "early" type and it really is the "late" type then I suspect they won't be selling many bushes...
