Manual / Auto shell
speedy555
Has thanked: 79 times
Been thanked: 38 times
Manual / Auto shell
Post by speedy555 » Sat Mar 02, 2019 10:12 pm
I'm pretty sure that a 5a Auto has a different transmission tunnel than a manual, but what about a 1970 se5 with 2 rod box and the auto version?
Dave Speed
GTC #7
Prev. 3x SS1/ 68 coupe/ numerous 5a & 6a /4x 6b's / Cipher / 3 x 69 se5 / rialto / Rochdale Olympic/ Gentry
5 series Registrar
www.ssgclassics.co.uk
www.facebook.com/ssgclassics
Fibreglass liquid coating technician - used spares
Has thanked: 189 times
Been thanked: 1281 times
Manual / Auto shell
Post by scimjim » Sat Mar 02, 2019 10:31 pm
Yep, the parts list shows manual and auto bodyshells (early and late, LHD and RHD) for SE5 and various manual/overdrive/auto shells for SE5a.
speedy555
Manual / Auto shell
Post by speedy555 » Sat Mar 02, 2019 10:33 pm
OK thanks....plan abandoned then :) :)
Dave Speed
GTC #7
5 series Registrar
Manual / Auto shell
Post by scimjim » Sat Mar 02, 2019 10:35 pm
I’ve seen at least one converted by simply glassing in the trans tunnel around the gearstick from the opposite type?
roymck
Has thanked: 15 times
Been thanked: 30 times
Manual / Auto shell
Post by roymck » Sat Mar 02, 2019 11:31 pm
It may well be that as Jim says the gear lever hole is different , it may also be that a auto shell,s bulkhead is not drilled for a slave cylinder.
Manual / Auto shell
Post by scimjim » Sat Mar 02, 2019 11:34 pm
The transmission tunnel is physically a different shape for each gearbox.
I once converted an auto 6a to manual overdrive and found the mould line for the clutch master cylinder hole when I took the paint off.
oilrag
Manual / Auto shell
Post by oilrag » Sun Mar 03, 2019 8:18 am
This topic is of great interest to me ,im seriously contemplating switching my 5a to C3 auto ,so much so i now hopefully have all the bits i need, but i have'nt as yet attempted to do a trial fit or indeed measured up the tunnel.Both motor and box are now removed.
Can i ask please what i need to alter/change body-wise to make this conversion possible (save for the pedal box alterations) ,im sure somebodies done this already.
I assumed the gear lever/ shifter positions would be different and would need a little glass-work but confess i hadnt reckoned on the tunnel being a different shape.
Thanks .
G
1980 GTC : 1972 SE5A and a few more long gone but not forgotten. Ex Middlebridge Employee.(12/88-05/90) RSSOC 3140
Manual / Auto shell
Post by scimjim » Sun Mar 03, 2019 8:31 am
If you look at the shape of the gearstick mounts - that’s the shape the tunnel needs to be. The auto is much flatter than the overdrive. The position fore/aft isn’t too critical as the rods/cable are adjustable on all of the boxes apart from the early overdrive (which has a fixed position stick anyway). I think it’s only the very first SE5 that have a physically bigger tunnel to take the auto.
oilrag
Manual / Auto shell
Post by oilrag » Sun Mar 03, 2019 9:36 am
Ahhh ,thanks Jim ,,thats not too tough to sort,i had visions of remodelling the bellhousing area as C3 does have a more gradual fall away from block mount flange compared to say a 3 rod o/d box .
G
briankenyon
Manual / Auto shell
Post by briankenyon » Sun Mar 03, 2019 9:56 am
Good Morning all,
Im presently restoring a 1970 se5 and my intentions are to convert from auto to manual using a 2rod O/D gearbox
Does this mean the transmission tunnel is different or as Jim says just a case of the gearstick position is different.
thanks
Manual / Auto shell
Post by scimjim » Sun Mar 03, 2019 10:23 am
The auto was launched in 1970 (451729) according to TSAIF (I suspect it was much earlier though), so despite the SE5 parts list not stating chassis numbers for the change, I’d say that’s a starting point. Anything earlier “may” need more tunnel mods but I’ve never seen one next to the other to confirm.
speedy555
Manual / Auto shell
Post by speedy555 » Sun Mar 03, 2019 6:46 pm
Mine is 450662, reg'd Feb '70
Dave Speed
GTC #7
5 series Registrar
Has thanked: 132 times
Been thanked: 875 times
Manual / Auto shell
Post by philhoward » Sun Mar 03, 2019 6:53 pm
450434 is (now) auto...so even ones pre-official changeover can be converted.
speedy555
Manual / Auto shell
Post by speedy555 » Sun Mar 03, 2019 7:00 pm
True, though mine isn't a conversion. 8)
Dave Speed
GTC #7
5 series Registrar
Manual / Auto shell
Post by scimjim » Sun Mar 03, 2019 7:38 pm
Is #662 an auto then Dave?
