Steering UJ wrongly phased Coupe
roymck
Has thanked: 15 times
Been thanked: 29 times
Post by roymck » Thu Feb 21, 2019 3:48 pm
The upper UJ on my column was siezed so ordered a new one from QRG . It’s wrong as it’s impossible to set the UJ correctly in line
with the lower UJ .
The UJ on the bottom end on the rack is one piece with the lower shaft , so you can only fit the upper UJ in line with the cut outs in the column and it’s totally wrong . Anybody else came across this as it’s bad engineering practice and I am not happy.
Been thanked: 279 times
Post by AJL Electronics » Thu Feb 21, 2019 5:23 pm
Can't see the issue, both ends are splined.
Has thanked: 103 times
Been thanked: 805 times
Post by philhoward » Thu Feb 21, 2019 5:25 pm
The issue is the bolt will only pass through with it in one orientation?
Been a while since I stared at the column UJs and splines but don't some parts have a groove all the way round and others just a slot (so fixing the rotary position)?
roymck
Post by roymck » Thu Feb 21, 2019 5:42 pm
On the old joint the bolts runs in line with the UJ , on the new joint the bolt is at 90 Dgs to the UJ. So if you assemble it up one joint would be horizontal while one was vertical . This will make the steering notchy !
The rack has a cut out all the way round so the lower joint fits on in any orientation . It is a sold forging with the shaft . The top of the lower shaft has a notch and the column has a notch as well . So both joints need to be inline or the shaft will rum out of true . Think of it like a propshaft the UJ,s have to run phases together . 2 ways round it cut a groove round the top of the lower column and spin the joint round or get the correct UJ . The pressed steel kind is listed on Car Builder Solutions .
Anybody else seen this problem ?
Been thanked: 417 times
Post by peter freeman » Thu Feb 21, 2019 5:44 pm
Run a drill through it or file - not that difficult to modify.
Has thanked: 167 times
Been thanked: 1170 times
Post by scimjim » Thu Feb 21, 2019 5:44 pm
Simple pic here to show the problem
Has thanked: 246 times
Been thanked: 183 times
Post by b.c.flat hat » Thu Feb 21, 2019 5:51 pm
Eh oop, Roy. See yer "Coupe thread".
(Beaten by them that tripe wi' more than one finger!)😳😁
roymck
Post by roymck » Thu Feb 21, 2019 6:20 pm
There are obviously 2 types of joint as seen on my first picture , both are available from Car Builders solutions so could have ordered the correct part from them if I had known .
Post by AJL Electronics » Thu Feb 21, 2019 6:35 pm
I understand phasing, but I can't see why you can't get it right by adjusting it on the splines. If it is 90 degrees out, then position one end 90 degrees out. Easier than getting it swapped out.
Post by scimjim » Thu Feb 21, 2019 6:37 pm
Because the bolt will only go through in one position, which will mean modifying the shaft.
Post by peter freeman » Thu Jul 04, 2019 4:37 pm
Started to put power steering in our Coupe ( slice report will be done ) and guess what the steering as above is 90deg out - I have a spare connection piece which is also 90deg out so I assume they were made that way originally. easy enough to put right but it makes you wonder how many other Coupes have the same arrangement - perhaps Reliant had a batch made all wrong and did nothing about it.
Chet
Post by Chet » Thu Jul 18, 2019 7:36 am
Mines "incorrect" and is all original, as far as I can tell - #400692.
Return to “Coupé”
