Broken Multi switch help
Has thanked: 32 times
Been thanked: 132 times
Post by Coupe Racing » Mon Feb 18, 2019 6:57 pm
Gents
I bought and received an SE6a multiswitch in broken condition.
Can anyone identify where the small piece of plastic comes from please ?
Broken part
Broken part.gif (174.75 KiB) Viewed 1731 times
roymck
Has thanked: 15 times
Been thanked: 30 times
Post by roymck » Mon Feb 18, 2019 7:26 pm
Might be part of the self canceling mechanism .
Has thanked: 219 times
Been thanked: 47 times
Post by willholderogri » Mon Feb 18, 2019 8:03 pm
That's one of the self cancelling arms it will work without it but won't srld cancel
Post by Coupe Racing » Mon Feb 18, 2019 8:19 pm
Thanks for the pointers.
Added to the problem is that the Headlamp flasher has no spring tension , so it wont stay in position , but is mobile between the contacts.
Thoughts ?
Has thanked: 178 times
Been thanked: 1230 times
Post by scimjim » Mon Feb 18, 2019 8:41 pm
It looks like the flash prong to me? Can get a comparison photo at the weekend if you still need it.
Post by Coupe Racing » Mon Feb 18, 2019 8:43 pm
That would be helpful thanks
Post by scimjim » Fri Feb 22, 2019 11:25 am
There should be a plastic arm on the flash lever inboard end Steve - provides the “spring” when you pull it to flash and locks the pawl when you push for main beam - your detached part looks like this to me?
Post by Roger Pennington » Fri Feb 22, 2019 1:13 pm
Here's another photo which may help (you can see how the plastic spring piece holds the moving toothed nylon part of the flasher arm against the single tooth on the switch body) :
Flash Switch.jpg (172.6 KiB) Viewed 1555 times
Post by Coupe Racing » Fri Feb 22, 2019 1:39 pm
Ah thanks - that makes sense.
Its not helping that the spring tension is also non existent.
Has thanked: 79 times
Been thanked: 212 times
Post by gtcse8 » Fri Feb 22, 2019 7:52 pm
Was only good for parts any way as the clamp ring is missing. :roll:
I have about 10 like that lol. :idea:
Been thanked: 117 times
Post by DARK STAR » Fri Feb 22, 2019 9:30 pm
You can mend the clamp ...
