Ti starting
hermeticist
Has thanked: 35 times
Ti starting
Post by hermeticist » Tue Feb 19, 2019 1:03 pm
Thank you for clarifying that. I think it is an area that I need to investigate...
Has thanked: 357 times
Been thanked: 255 times
Ti starting
Post by Corky » Tue Feb 19, 2019 3:51 pm
The stock regulator is good for 200hp (It was on my Sabre anyway), so unless it's broken I wouldn't bother. Having said that I will be changing the one in my Sprint car in the next couple of weeks for a Sytec MSV with built in gauge. This is because I don't trust the one that's on there and I want to know exactly how much pressure I'm getting (I'm practically redlining at every up change whilst on track). I'll post photos in my project thread so you can see where to cut out the old regulator etc.
hermeticist
Ti starting
Post by hermeticist » Tue Feb 19, 2019 6:10 pm
That would be great Steve, it's not in the search for more power but in resolving the issue of overfuelling and poor running...
Dave Eddy
Ti starting
Post by Dave Eddy » Wed Apr 03, 2019 4:36 pm
Ok chaps, my issues continue tho i must admit ive only got one thing (i hope ) to resolve, the car starts, but still a little reluctantly and it dosent pick up the revs at all as you would expect a cold car to on start up and i doubt you could drive away in it without stalling, What am i missing here to get the revs up on start-up , the bummer is that if i run it till its warmed up it runs REALLY sweet. Ive tried the air regulator, tested continuity, OK, checked feed from ECU,OK about 12+V, cannot open it up cos its sealed, when its on tried connecting and disconnecting its electrical connections but neither seem to make any difference, Bluebird manual suggests clamping off the rubber pipe ,U-SHAPED, into it and revs should slow, it doesn't !!
Suggestions Please
Ti starting
Post by Corky » Wed Apr 03, 2019 4:44 pm
Check the ignition timing and idle speed. If it’s a gnat’s out on either, it can cause these symptoms.
Hot idle should be about 1100-1200 rpm (yes, pretty high, but it helps stop exhaust smoke at idle). Iirc the timing should be set when it’s running at 850-950rpm, when set turn the idle screw until it reaches 1100-1200rpm.
old bean
Ti starting
Post by old bean » Wed Apr 03, 2019 10:57 pm
Still sounds like a coolant temperature sensor issue. Have you tried a new one? What about trying another ECU?
Dave Eddy
Ti starting
Post by Dave Eddy » Thu Apr 04, 2019 3:48 pm
Yes ive fitted a new temp sensor unit with no change but haven't got a spare ECU , reluctant to buy one as all the bits ive previously bought to try and fix it haven't worked.
hermeticist
Ti starting
Post by hermeticist » Thu Apr 04, 2019 10:17 pm
I have an ecu that is currently not on a car (it's not exactly a spare and I would need it back...) but I don't know if it is good... So not exactly a massive help but you could borrow it to try?
old bean
Ti starting
Post by old bean » Thu Apr 04, 2019 11:08 pm
Two adjustment screws near the idle valve on the inlet. One facing the drivers wing adjusts base idle speed, one 90 degrees round the side of it, facing the radiator should control the idle up circuit idle speed / cut in. Worth a tweek of either to see if you can stable out the idle up (choke) engine idle speed.
Clutching at straws here but make sure the looped air hose linking the inlet to the idle up valve is intact, done up tight and not perforated, as a leak on the hose would make it run lean on a cold start until the valve closed.. Worth a check on all your air inlet and turbo hoses for leaks too.
Dave Eddy
Ti starting
Post by Dave Eddy » Fri Apr 05, 2019 9:57 am
Thanks guys, willing to try anything now, Cheers
Dave Eddy
Ti starting
Post by Dave Eddy » Tue May 07, 2019 4:32 pm
OK, i think i have tried, REPLACED everything now, new dizzy and crank angle sensor, new ecu temp sender, new air regulator, new fuel pump,replacement throttle switch, cleaned out iaa unit, new dizzy cap and rotor arm, new plugs, checked leads, extra earth leads, tried replacement ECU (no Change) Current situation is ,takes 3-4 cranks to hesitantly start then picks up to about 1500rpm then steadily rises to about 2000rpm where it stays even up to full temp, can't slow it down ?? no air leaks i can detect, no adjustment left on idle adjustment, it does drop revs somewhat if i adjust angle of throttle switch ???
Where to now ????????????????
td99
Has thanked: 17 times
Been thanked: 36 times
Ti starting
Post by td99 » Tue May 07, 2019 7:14 pm
maybe silly question, but does the throttle butterfly close properly?
Has thanked: 109 times
Been thanked: 161 times
Ti starting
Post by reliant-reviver » Tue May 07, 2019 9:32 pm
Air flow meter ?
Dave Eddy
Ti starting
Post by Dave Eddy » Tue May 07, 2019 10:08 pm
Thanks guys, two more jobs for tomorrow .
old bean
Ti starting
Post by old bean » Tue May 07, 2019 10:43 pm
Did you have the timing belt off for the rebuild, or did it stay in place?
