GTE Engine & Gearbox Removal
housemartin
Post by housemartin » Sun Nov 18, 2018 5:45 pm
Evening,
Given your widespread experience, is it easier to remove the gearbox and engine as a complete unit or separately?
I have an engine hoist, but have always removed one or the other never both at the same time.
Just wondered if it is possible and how easy it is to keep it balanced and if it was quicker.
Any links photos greatly appreciated
Dan
Joe.
Post by Joe. » Sun Nov 18, 2018 6:57 pm
I've done it both ways and always found it easier to lift engine and gearbox together, I do have a big engine crane though.
On a GTE you'll need the front of the car to be raised a bit to stop the bottom of the gearbox grounding out. If you've only got a small / standard size engine crane you may struggle to take both out at once.
Can't help with photos as the only pictures I seem to have were taken while lifting a straight 6 coupé engine.
TrevorG
Post by TrevorG » Sun Nov 18, 2018 7:43 pm
I did an engine gearbox removal last week and with advice from all here it was so easy with a crane. I had the whole car up on axle stands, but you only need to do the front, then when engine and box had come up and forward so pulley is about an inch from bonnet catch, I took the stands out and dropped the car to its wheels which enabled moving the car backwards with plenty of clearance....nothing touched. I did find it easier to move the car as trying to move the crane with engine/box started it swinging. All done on my own. I made up a hanger plate for the carb bolts which canted the engine perfectly. If you want pics shout.
rkclodhopper
Post by rkclodhopper » Sun Nov 18, 2018 7:47 pm
If your using a lifting hoist, the type on wheels, you need to make sure the reach is sufficient, the engine is a long way back.
Richard
TrevorG
Post by TrevorG » Sun Nov 18, 2018 7:50 pm
A two tonne crane that has extensions down to 1/2 tonne is fine. Half tonne is ample to lift and reach is fine.
TrevorG
Post by TrevorG » Sun Nov 18, 2018 7:57 pm
housemartin
Post by housemartin » Sun Nov 18, 2018 11:25 pm
Guys,
That is fantastic.
Especially the photos.
I will set about making a plate for carb bolts.
It amazes me that 4 bolts can support such a weight.
I also like the idea of rolling the car back rather than the crane.
Nice scimitar rocker covers.
Dan
TrevorG
Post by TrevorG » Mon Nov 19, 2018 1:12 pm
Good luck with your engine out, certainly easier putting back in one piece! The rocker covers came from robin rew when he modded the engine for me many years ago so don't know if any more still around. I'm going to polish them back up as I don't know why someone painted them whilst car was out of my ownership.
