Body re-inforcement metal parts SE5/a - dxf files
Pepe
Post by Pepe » Fri Jul 29, 2016 11:19 am
Guys , I decided to remove the password from the dxf. Have fun...
Hello all,
I want to share some dxf files with you that I created to support my SE5a re-build in another thread here.
These came in handy during the restoration, especially the door inner and turret re-inforcements to support the heavy battery and avoid body cracking on near the turret
- Dropbox Link - updated to new dropbox location 20180220 - now without password - please leave a "thank you" when downloading :) -
Edit 05.06.2018: ....well, wll, well... Somehow it doesn't work and i still receive some requests for the password. So I better simply post it here (take care of UpPeR_LoWeR case):
DXF_files_GTESE5a
Some of the files are also available here a drawings or electronically so they may overlap and I thank the guys that have created them! Having the dxf files available you should be able to have them stamped at a metal-guru :)
The zip is password protected, please request via email through this forum, so I can track roughly who gets the files...
thanks
Christian
1975 SE5a restoration link
Image Image
Been thanked: 564 times
Re: Body re-inforcement metal parts SE5/a - dxf files
Post by Roger Pennington » Wed Aug 03, 2016 11:38 am
Hi Christian, as promised I've made this a sticky so your work will be preserved for posterity :D
ficknoster
Post by ficknoster » Wed Apr 05, 2017 3:27 pm
Oh no! :shock: File not found!
Is there an updated location of this life saving dxf file? Does anybody happen to have it saved?
Thanks!
Has thanked: 87 times
Been thanked: 736 times
Post by philhoward » Wed Apr 05, 2017 3:39 pm
DXF files can't be added to the forum normally but if emailed to me, I'll be able to ;)
Been thanked: 122 times
Post by ScimmyMike » Wed Apr 05, 2017 4:15 pm
philhoward wrote:DXF files can't be added to the forum normally but if emailed to me, I'll be able to ;)
It's the dropbox folder that's gone AWOL Phil, DXF would have been in there
Post by Roger Pennington » Wed Apr 05, 2017 7:59 pm
Pepe wrote: The zip is password protected, please request via email through this forum, so I can track roughly who gets the files...
thanks
Christian
In his original note, Christian wrote the note above, so a working dropbox link, on it's own, won't help you. You need the password as well. Might be worth a PM to Christian?
ficknoster
Post by ficknoster » Wed Apr 05, 2017 8:41 pm
Already PM'd and replied. It is indeed a dropbox issue.
Pepe
Post by Pepe » Wed Apr 05, 2017 8:44 pm
I have updated the dropbox link which now works again.
Dropbox has shut down support for the "PUBLIC" Folder they have invented some time ago. I now need to edit each and every thread to the new links...
Page 23 so far :)
Please continue to request the PW via email or PM.
Christian
Image Image
Post by Roger Pennington » Wed Apr 05, 2017 10:07 pm
Well done Christian, thanks for sorting that :D
Post by ScimmyMike » Thu Apr 06, 2017 9:35 am
Pepe wrote:I have updated the dropbox link which now works again.
Page 23 so far :)
Christian
Ah, I'd forgotton about that, don't you just love the way these companies operate, offer loads of storage then slam the limit down meaning like me you end paying just to get your stuff back because you can't organise into folders to retreive cause there isn't free space and you can't download it all at once because there's too much data! I am now looking for a cheaper alternative like my own NAS box at home possibly
Pepe
Post by Pepe » Tue Feb 20, 2018 8:56 pm
removed password ....
Image Image
PaulS
SE5/a dxf files
Post by PaulS » Tue May 15, 2018 1:59 pm
I am having problems down loading the above files, I using an old PC (XP) as I have problems with my more modem PC at this time. Any help would be good and if anyone has already got them could they email them to me
Many Thanks
Post by philhoward » Tue May 15, 2018 2:07 pm
No password on the download, but a password is still needed to unzip/open the files? Do you still want a PM for this, Christian?
DXF_files_GTESE5a.zip
(699.83 KiB) Downloaded 137 times
Posted here for those who don't have Dropbox (or don't want to sign up).
SE5/a dxf files
Post by philhoward » Tue May 15, 2018 2:08 pm
I've added them to the sticky as an attachment (which might make it easier for you) although the ZIP file still needs the password from Pepe to unlock them.
PaulS
SE5/a dxf files
Post by PaulS » Wed May 30, 2018 11:23 am
I have sent emails to Pepe about obtaining the password for the ZIP files, but have not recieved a reply, can anyone help please
