Race Chrono
Been thanked: 70 times
Race Chrono
Post by Nick » Fri Mar 23, 2018 10:10 am
Tried the free app at Curbs.
Whilst the timing was about 3 secs short (presumably the start), the lap charts are very interesting with speeds etc. helpful with gears and lines.
Anyone gone for the chargeable update? Benefits?
Has thanked: 167 times
Been thanked: 1172 times
Race Chrono
Post by scimjim » Fri Mar 23, 2018 10:28 am
I bought the pro version for iPhone - looks very good but I haven’t played with it much yet.
You can see by the time and distance that the last lap didn’t capture properly
And you can see from the track that it wasn’t very accurate - which is probably mainly a result of the poor signal you always get at Curbs
And this is the top bend where you can see from the graph that it’s lost signal
PeterSM
Been thanked: 32 times
Race Chrono
Post by PeterSM » Fri Mar 23, 2018 1:18 pm
I used an external GPS device which was a bit of an issue to set up but shows better accuracy (but worse lap times :) )
This woild have been using GPS signals not a mixture of GPS and GSM.
Peter Smith
SS1 Sprint Car, 1800Ti SS1 and a very special Sabre DET
Has thanked: 39 times
Been thanked: 51 times
Race Chrono
Post by nickkeyser » Fri Mar 23, 2018 2:31 pm
That’s more like it. Is that still on a phone but with an external GPS hooked in?
SSSC Champion 2019
SS1 CVH 1600Ti
Race Chrono
Post by Nick » Fri Mar 23, 2018 3:17 pm
Mine looks very similar on the standard phone and app
PeterSM
Race Chrono
Post by PeterSM » Fri Mar 23, 2018 5:19 pm
Yes mine was on the phone with an external GPS.
Accuracy of the position may be phone/network dependant. I used a Samsung S7 on EE. Hooked up to a Garmin GLO
Initially this device did not appear to be working it will connect to Apple devices like an ordinary Bluetooth device but not android.
Also I had problems because it was mounted out of reach, when not in use it goes into power save and had to be turned back on.
I also have some GoPro footage I should be able to link once I have the time!
Peter Smith
Race Chrono
Post by Nick » Sun Jun 09, 2019 12:03 pm
I find this very useful, comparing times gearing etc.
At the moment it is all on my phone. Anyone been able to .load sessions to a desktop? if so, how? I have an Android phone and an I mac
Race Chrono
Post by nickkeyser » Sun Jun 09, 2019 12:30 pm
I bought this earlier in the season an tried it at goodwood but wasn’t that convinced with the gps tracking.
It looks like I need to work on my lines around most of the track. Do you get better results than this? It may be due to the Stealth styling of my car making it undetectable from space...
SSSC Champion 2019
SS1 CVH 1600Ti
Race Chrono
Post by Nick » Sun Jun 09, 2019 1:18 pm
It does depend on the quality of your GPS. Obviously comparisons between runs and events are valid. Helps me decide when to stay in 3rd, go to 4th etc. I presume you get speeds at points on the track overview, and graphs of speed against time?
Race Chrono
Post by scimjim » Sun Jun 09, 2019 1:50 pm
As above, mPS was way off at Curborough - Peter Smith has a remote GPS receiver in the roof of his car, which is much more accurate.
Can’t help with loading to desktop at the moment as I’m not home but will try it next week.
