Windows 10 folders
Has thanked: 29 times
Windows 10 folders
Post by swoakes » Tue Feb 27, 2018 5:53 pm
When I plug my phone into my laptop and browse the camera folder on its SD card the files are difficult to sort because the laptop seems to think the folder contains music files not image files.
I want sort the files by "date taken" but this is not an option for the reasons above.
How do I tell Windows that the folder contains image's :?:
PeterSM
Been thanked: 29 times
Windows 10 folders
Post by PeterSM » Wed Feb 28, 2018 8:26 am
Can you go to the View menu and then select Detail?
Peter Smith
SS1 Sprint Car, 1800Ti SS1 and a very special Sabre DET
Windows 10 folders
Post by swoakes » Wed Feb 28, 2018 9:18 am
I Looked into this further last night Peter.
If i plug the phone into the laptop and browse to the camera folder; the folder is setup for music files giving options to sort by for example artist, track no etc.
If I take the SD card out of the phone and plug it directly into the laptop and browse to the folder I am able to say that the folder contains photos and then all the sort options become available such as date taken, focal length etc :roll:
I think it has something to do with the way windows treats devices. The phone is not allocated a drive letter when I plug it in its just called Steve's A5. When I plug the SD card in it is allocated a drive letter.
Just not sure which device is controlling what.
I am able to sort the folder by "date created" when I plug the phone in which is fine most of the time. However when you copy/paste or move photos taken earlier into that folder the date created is the date you did that not the date the photo was actually taken. I want to ideally sort by "date taken" in that folder so that photos always display in a logical order on my laptop.
Been thanked: 117 times
Windows 10 folders
Post by ScimmyMike » Wed Feb 28, 2018 9:26 am
Right click the section where it says artist, track, time etc and a drop down box appears, select the ones you want.
Windows 10 folders
Post by swoakes » Wed Feb 28, 2018 9:44 am
I can't Mike because the options I want relate to Image files and the options its giving me are for Music files like you show above.
When I plug my phone in I don't have the option to customise the SD card Camera folder to say it contains images
Windows 10 folders
Post by ScimmyMike » Wed Feb 28, 2018 10:12 am
just tried my phone, once I'd navigated to the image library on my micro sd card my default setting was thumbnails which I change using top view command, then get the screen shot below, presume you don't get that Steve, can you post what you're seeing perhaps?
phone shot.jpg (102.4 KiB) Viewed 1870 times
Has thanked: 135 times
Been thanked: 499 times
Windows 10 folders
Post by Roger Pennington » Wed Feb 28, 2018 10:32 am
First, Right click on the folder icon in the left-hand pane of file explorer, then left-click on "properties" then left click on the "Customise" tab, then select the dropdown "optimise this folder for" and you'll get the options shown below. Change from music to pictures, click on ok to save, and I think you'll be sorted :D
screenshot music.jpg (99.74 KiB) Viewed 1866 times
demonbluedays
Windows 10 folders
Post by demonbluedays » Wed Feb 28, 2018 10:55 am
Sometimes windows can be a pain in the plums
Rogers suggestion should work, but sometimes it can throw a wobbler
The problem comes down to the phone software and windows software banging heads
My Xperia Z5 premium (android...with some tasteful modifications to utilise the system power and memory fully)90% of the time will allow Windows to see and organise them as it would like to, but the other 10% is windows attempting to "tell" the phone what to do, and then you get images listed as music, videos listed as unreadable formats and some off the apk files for apps as bootable software (that will crash the system and phone together if you try , I learnt that the hard way!) because the phone software is being stubborn.
With the Sd card out there's no external operating system to clash with, so it's free to sort itself as it sees fit.
Worst comes to worst download the manufacturers phone support software (if available) as that will allow you to edit add delete and move files to your hearts content usually without headaches.
Tom "DemonBlueDays" Williams
1976 SE6 #141 "Mighty"
2009 Fox "King"
Former Owner Of
Windows 10 folders
Post by swoakes » Wed Feb 28, 2018 12:56 pm
I don't have the option to customise the folder when I plug the phone in.
I'll see if Samsung have some software I can use Tom.
Terry H
Been thanked: 46 times
Windows 10 folders
Post by Terry H » Wed Feb 28, 2018 2:52 pm
When I have a problem with my phone I usually do a "how to fix etc etc" in the search bar on Youtube. Hope this helps.
Regards Terry H
1185
Windows 10 folders
Post by swoakes » Wed Feb 28, 2018 5:26 pm
Thanks Terry. Gave it a quick try but it comes up with all kinds of stuff on folders when I enter logical search terms. Some of it may be relevant but which bits in amongst that lot is difficult to say.
I installed the Samsung software and that is equally unhelpful as it also displays folder contents in the wrong order which cannot be changed.
I give up for now :)
Windows 10 folders
Post by ScimmyMike » Thu Mar 01, 2018 12:00 pm
Steve, my 2nd screenshot was of my Samsung S7, puzzled as to why your's would be different
Windows 10 folders
Post by swoakes » Thu Mar 01, 2018 12:09 pm
Looking at that second screenshot I think you have the same issue Mike :?:
Can you customize that folder to sort jpg files in "date taken" not date created/ modified?
I am able to customize a folder on the laptop but not a folder on the phone SD card displayed on the laptop when I plug the phone in.
I think Tom is correct above; windows and phone SW not quite talking the same language :(
Windows 10 folders
Post by ScimmyMike » Fri Mar 02, 2018 9:19 am
Steve, just checked on my office PC, the date modified is actually the date the photo was taken and matches what my camera gallery tells me, the date created for some bizzare reason appears to be the date the item was created, i.e. moved to the current location, in this instance a folder on our server and is 2 days after I took the photo which is correct, weird windoze terminology it seems for some reason, you'd expect the created date to be shot date and modified to be date moved to the computer location, don't know whether that helps at all?
Windows 10 folders
Post by swoakes » Fri Mar 02, 2018 10:05 am
Thanks Mike. I think it helps in that yours is the same as mine and strengthens Tom's argument that its a windows/ Samsung thing.
The "date taken" value never changes even when copied, pasted or moved to another folder. It is a constant stored somewhere within the jpg file.
It's therefore the ideal way of sorting photos into chronological order when you have files copied and moved to a common "photos" folder from other devices.
It's beaten me for now :evil:
Thanks for your help all :!:
