rocker cover gaskets
Been thanked: 417 times
Post by peter freeman » Sat Oct 07, 2017 10:10 am
Not been able to find and rubber rocker cover gaskets for the 2.9 - are they made - if so by who and where can they be bought.
Peter
Has thanked: 66 times
Been thanked: 200 times
Post by gtcse8 » Sat Oct 07, 2017 10:54 am
I got lots of the cork type Peter.
Last time I saw the rubber ones for Essex they were 5 times the price of cork so I never bothered stocking them.
Have you got original pressed steel covers or alloy, the alloy can be a pig to seal with the rubber type.
There are also different thicknesses of cork for sale, if you use the thickest type they are prone to splitting at the screw holes.
Mark Wilson. Garage sale everything must go. :cry: SE5a`s, GTC, SE6b`s, Triumph Daytona, Honda CB750 K7. Also on YouTube :wink: lookup V8 Chevy https://youtu.be/lbpvDGAMY6g https://youtu.be/7xTrbr0ETSA https://youtu.be/K7HfYVd5Flo
Post by peter freeman » Sat Oct 07, 2017 11:10 am
Planning to get the alloy covers that's why I will need to get new gaskets - will get in touch with you ( again ) when the covers are ready.
drcdb15
Has thanked: 32 times
Been thanked: 30 times
Post by drcdb15 » Sat Mar 31, 2018 10:35 pm
What is the latest position on the cork gaskets ? (as I am about to get around at long last to fitting my alloy covers too). What are the reasons for the different thicknesses of cork? And is there any recommended sealant to use with them, or just fit the cork dry?
Chris
Been thanked: 70 times
Post by Nick » Sun Apr 01, 2018 8:43 am
Clean flat surfaces, personality I seal to the head to ease future box removal. Key is to not over tighten
Post by gtcse8 » Sun Apr 01, 2018 10:21 am
If fitting to Ally covers check if they have the recesses machined to retain the gaskets, if they just flat surfaces then I glue the thinnest gaskets to the covers and then don`t go mad with the M6 bolts.
Trying to glue a gasket in the correct place on a Cologne head is difficult, just easier to clean the cover and either use impact adhesive with a thin brush, or spray glue and let it set before fitting.
simmit
Has thanked: 131 times
Been thanked: 8 times
Post by simmit » Sun Apr 01, 2018 12:08 pm
I used 'ThreeBond 1104Neo Plus' without gasket when I fitted alloy covers. So far so good!
What's to lose by trying?
Return to “Middlebridge”
