2.9efi thermostat & gasket
simmit
Has thanked: 126 times
Been thanked: 8 times
Post by simmit » Sun Jun 25, 2017 12:19 pm
Preparing to remove thermostat housing and wanting to have correct thermostat (if needed) and gasket to to hand for reassembly.
For the 2.9EFI engine I'm finding thermostats of various temperatures being recommended (84C, 88C?) and am unsure about gasket type required as illustrations seem ambiguous (rubber seal or traditional gasket?).
Grateful for advice on temp. and gasket type please.
Been thanked: 119 times
Re: 2.9efi thermostat & gasket
Post by ScimmyMike » Sun Jun 25, 2017 10:17 pm
If the same as the 2.8 cologne which I'd suspect it would be heads aside then there are both rubber ring type, square in section as well as the traditional gasket, as for temp sorry couldn't really comment on the 2.9 as may differ from the 2.9, speak to Greeny as he has a 2.9 in his GTC
simmit
Post by simmit » Tue Jun 27, 2017 10:38 am
ScimmyMike wrote:If the same as the 2.8 cologne which I'd suspect it would be heads aside then there are both rubber ring type, square in section as well as the traditional gasket, as for temp sorry couldn't really comment on the 2.9 as may differ from the 2.9, speak to Greeny as he has a 2.9 in his GTC
Thanks. It seems 2.8 and 2.9efi are different. Have now discovered 2.9 has round section seal (not square) with slit along inside circumference to accept thermostat plate and does not have additional gasket. Thermostat temp. is generally given as 88C.
Return to “Middlebridge”
