Manny's SS1 1600
Been thanked: 473 times
Manny's SS1 1600
Post by Roger Pennington » Mon Apr 30, 2018 2:57 pm
Ah yes, thinking back to when I've done it, and looking at the photos from the time before last, (which are in my project thread), I think the reason I didn't remember any great struggle to remove the crank pulley is because I was only changing the belt, not doing the oil pump or seals, and I think once the fanbelt pulley is off there is enough space to remove the belt without removing the pulley. So ignore my ramblings! :roll:
manny
Has thanked: 33 times
Manny's SS1 1600
Post by manny » Mon Apr 30, 2018 5:54 pm
sir..i never view your posts as rambles :) and never ignore- as this reply proves
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sat May 05, 2018 6:06 pm
Good sunnnnnny day all,
with the puller in hand- removing the toothed pulley was a 5 min job, and the keyway came out within 1 min...
....well i managed to renew the seal - then realised i had put the tooted crank pulley on backwards!!- so tempted to lever it out - and chipped it :oops: - but it does not interfere with the belt - but will replace it once i manage to source a spare...
Put it back together - i had used some white nail varnish to mark the belt prior to removal - so it went back on without too much drama....and it all worked :D phew....
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Mon May 07, 2018 3:26 pm
There i was all happy that the crankshaft oil seal was doing its job...when i saw oil leaking from the camshaft seal!...oh well at least i found it ..one of the causes!
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Wed May 09, 2018 7:18 pm
Good day all
having got the car running - i noted that it 'seems' to run smoothest\best when the distributor is near the end of its rotational travel- would that suggest a camshaft change is in order? - i have not had it timed- just tweaking when listening ..
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 24 times
Been thanked: 34 times
Manny's SS1 1600
Post by Alan SS1 » Thu May 10, 2018 12:52 pm
Good day all
Ta
Manny
simple thing first
Check that vacuum advance pipe isn't broken/ split. try removing it at dizzy end then put your thumb over carb end, see if it runs better /worse.
also check that the pipe to servo is 'unmolested', again plug if needed to try
I doubt a cam change is required, but are you 100% you got the dots lined up when you swapped timing belt? :shock: one tooth will make heck of a difference :wink:
manny
Manny's SS1 1600
Post by manny » Thu May 10, 2018 2:16 pm
Good day all
Ta
Manny
simple thing first
Good day Alan,
before i removed the belt:
i used red nail varnish and highlighted four points on the belt - and two on the Camshaft Sprocket ( engine at TDC with the Crankshaft and Camshaft sprockets aligned with their relative markers)
two on the belt either side of TDC position
Two adjacent on the belt ( pinched the belt) near the water pump
and installed exactly as removed - the engine made no differing noises as prior to removal (fairly quiet)
I also used it to get to work this morning - without any noticeable way it drove etc...
Will check as suggested later today..
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1600
Post by Alan SS1 » Thu May 10, 2018 7:26 pm
OK, just a thought as if ran OK before changes and now it ' is less so' always good to start at last thing touched :wink:
My goodness that's keen, I've really just put it in gear and handbrake on!!
maybe a dab of tippex to mark the head of the tensioning bolts and where the tension was, more as a guide than anything else
Did you get permission to use that much nail varnish :shock:
manny
Manny's SS1 1600
Post by manny » Thu May 10, 2018 7:38 pm
:D ....well she has not noticed it so far.!
as this was my FIRST EVER ( yes really!) timing belt removal ..thought i'd better be sure it goes on the same way ..
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sat May 12, 2018 6:31 am
Good day ,
i have a trip to Droitwich this morning ( 60 miles total on M5)- so will report if\when i make it back!
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sat May 12, 2018 8:36 am
Well all went well!...so not sure what to look at next regarding the distributor or just leave as is :?
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sun May 20, 2018 9:22 pm
Good day all ,
today, my embarrassing question....
how will 1600 run with a 1300 distributor- as my installed dizzy has a one mount lug missing - but i have a spare ( 1300 i think) dizzy--
so can i install it and try to run it without any major mishap? before i figure out how to swap the housing it self..
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1600
Post by scimjim » Sun May 20, 2018 9:37 pm
I’d imagine they have different advance characteristics and would make the 1600 a bit more sluggish?
manny
Manny's SS1 1600
Post by manny » Sun May 20, 2018 9:56 pm
..that i can live with - cheers-
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1600
Post by scimjim » Sun May 20, 2018 10:00 pm
I probably have spares - can look tomorrow if you want?
