Manny's SS1 1800 Ti
Has thanked: 154 times
Been thanked: 158 times
Manny's SS1 1800 Ti
Post by Corky » Sat Aug 12, 2017 5:42 pm
If you follow the dizzy inserting procedure to the letter, and check that the rotor arm is pointing towards the cylinder no.1 lead. It should start instantly.
I usually leave the securing bolt hand tight, so I can fiddle with the timing once it's running.
Sounds like you're very close !
Well done :D
Manny's SS1 1800 Ti
Post by Corky » Sat Aug 12, 2017 5:44 pm
CNHSS1 wrote:
Fri Aug 11, 2017 5:57 pm
Dunno whos more offended me or Corky :lol:
Personally I wouldn't bother, there will always be annoil.mist on internals, mainly from idling when the turbo seals aren't as fully pressurised as they could be, when giving it the beans it will disappear anyway.
If it's to make the outside of the engine loom prettier, I'm definitely not your guy, but Corky or one of the other Cheshire Polishing Brigade will be ;-)
Just seen this...... :w :lol:
manny
Has thanked: 33 times
Manny's SS1 1800 Ti
Post by manny » Sat Aug 12, 2017 5:51 pm
Well done :D
Good day sir ( Corky? :D )...the dizzy was not disturbed by me ..but yes that fact we got backfire did make me smile- i just read the dizzy 15 degree rotate before installing section - so hopefully i can upload a video tomorrow of it firing ...
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Been thanked: 876 times
Manny's SS1 1800 Ti
Post by scimjim » Sat Aug 12, 2017 6:04 pm
Possibly gummed up injectors and/or plugs if the last turbo was oiling the inlet tract :D How long since it last ran?
manny
Manny's SS1 1800 Ti
Post by manny » Sat Aug 12, 2017 11:02 pm
not sure when it was last run...i guess two years...i was tempted to dismantle the inlet side and soak the injectors in some cleaner... once i have checked the timing\dizzy first..
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1800 Ti
Post by Corky » Sun Aug 13, 2017 10:11 am
Ta
Manny
I'd avoid doing that if you can..... A right PITA when the engine is on the bench let alone in the car. Just try and get it running and put a cleaning aditive into the fuel if you think it needs it.
manny
Manny's SS1 1800 Ti
Post by manny » Sun Aug 13, 2017 10:44 am
Ta
Manny
Morning sir - okay will do - I was ready to throw in the towel and get the car to my mechanic- but as i am (hopefully) so close - it would feel good to get it going under my own steam... i will be heading out to the garage in an hour- so will report back later.
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1800 Ti
Post by manny » Sun Aug 13, 2017 3:53 pm
:D well it's alive!!! Badly misfiring - when pulling the leads from the dizzy - each one changed the note of the engine - so I have done something right ! At rough idle - should the turbine be spinning or not? Mine was sometimes moving - but when I applied a little throttle it did spin ok ....will check the plugs now and post a video later
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1800 Ti
Post by Corky » Sun Aug 13, 2017 3:59 pm
How can you see if the turbo is spinning? Have you got the hose from the MAF disconnected?
It will run very rough if that's not in place.
manny
Manny's SS1 1800 Ti
Post by manny » Sun Aug 13, 2017 4:40 pm
ah..that may explain it...i had the MAF connected but not the hose...may explain the video below then.. :oops: ...lots of un-burnt fuel..
https://youtu.be/bm8Gp4D_uMs
https://youtu.be/CZ2e7gpKjkQ
will pick it up next weekend ..but happy non the less :D if the symptoms in the video are due to the MAF - then i am looking forward to next weekend.
thank you all for helping me getting this far!!
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1800 Ti
Post by Corky » Sun Aug 13, 2017 4:51 pm
All those hoses need to be connected. That includes the one to the rocker cover. Air leaks in these are often discovered when a Ti starts to run a bit rough.
Well done getting it running though :hurrah: 8)
manny
Manny's SS1 1800 Ti
Post by manny » Mon Apr 02, 2018 3:06 pm
Good day all
Back on this one now, reassembling the turbo to manifold , one of the studs dropped out as below , will JB weld be the best way forward
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 77 times
Been thanked: 119 times
Manny's SS1 1800 Ti
Post by reliant-reviver » Mon Apr 02, 2018 3:45 pm
JB won't withstand the temperature. Heli-coil thread repair is the way to go.
manny
Manny's SS1 1800 Ti
Post by manny » Mon Apr 02, 2018 4:29 pm
bugger...okay a process i have heard of but never attempted...so will read up and post before i attempt :cry:
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
td99
Been thanked: 22 times
Manny's SS1 1800 Ti
Post by td99 » Mon Apr 02, 2018 9:17 pm
Or drill deeper and extend the thread and use longer stud. That would be my first choice. Even if you drill through to inside, you can seal the thread.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
