GTC Vert Soleil
Been thanked: 98 times
GTC Vert Soleil
Post by gtcse8 » Tue Jan 02, 2018 10:04 am
Was only taking the P over a scruffy motor LOL
Has thanked: 57 times
Been thanked: 87 times
GTC Vert Soleil
Post by Oldconn » Tue Jan 02, 2018 10:16 am
Ah,Sorry Chris! I meant the comment about the door lines, not the hub caps! :lol:
Been thanked: 74 times
GTC Vert Soleil
Post by DARK STAR » Tue Jan 02, 2018 11:13 am
No problem :cloud:
Speaking of taking the piss, where is Duncan (V8 supercharged Coupé), I miss him?
GTC Vert Soleil
Post by DARK STAR » Thu Jan 11, 2018 6:36 am
A last (I hope) note on doors, I was slightly irritated after adjusting the thing to the nearest thousandth of a millimetre to find that it still tended to stick shut.
Further investigation finally revealed that some bright spark had previously lubricated the striker socket with a vicious grease which seems to have transformed the rubber bit into black Bostik.
Cleaned out and lubricated with silicone, the operation is now silky smooth.
Has thanked: 71 times
Been thanked: 91 times
GTC Vert Soleil
Post by b.c.flat hat » Thu Jan 11, 2018 9:07 am
Chris, it's not "silky smooth", it's "smooth as a zephyrs phart".
GTC Vert Soleil
Post by DARK STAR » Thu Jan 11, 2018 11:46 am
I like that, but I'm sure it's not an expression I ever heard in my part of Yorkshire.
In fact I'm sure the only zephyrs ever seen (or heard ;-))
in Yorkshire were made by Ford.
GTC Vert Soleil
Post by DARK STAR » Thu Jan 11, 2018 5:30 pm
I had forgotten the problem of the exhaust touching the body until I was looking under the door 8)
Today as planned I got in the pit to loosen the engine mounts - and found one was already loose.
Normal.
Undid the other mount and jacked up on one side to try and lower the exhaust on the other side.
To my surprise it seems to have worked, there is little clearance but the exhaust no longer touches so one more idiocy to tick off.
Then a drop of water fell on my head.
Blue water.
I had noticed the coolant level going down a bit but just thought it was being spat out, as can happen.
This seems to be coming from the fuel pump blanking plate, which apparently has been fitted without a gasket :roll:
Two questions
Is it normal that there is water in the old petrol pump drive (I've checked and there is none in the oil!) ?
Has anyone a gasket or a bit of gasket paper so I can make one, otherwise I'll have to buy a bottom-end set.
Has thanked: 120 times
Been thanked: 888 times
GTC Vert Soleil
Post by scimjim » Thu Jan 11, 2018 5:49 pm
I think you need to look for a different source for the leak - the fuel pump blank might leak oil but never coolant.
GTC Vert Soleil
Post by DARK STAR » Thu Jan 11, 2018 5:54 pm
That's what I suspected :roll:
Been thanked: 561 times
GTC Vert Soleil
Post by philhoward » Thu Jan 11, 2018 5:58 pm
Has your engine movement found a weak hose connection?
GTC Vert Soleil
Post by gtcse8 » Thu Jan 11, 2018 6:16 pm
Yup I agree with Jim.
The fuel pump can only be in contact with the internal block castings, which only contain oil.
On the 2.8 there is the "Transfer" pipe for coolant from the thermostat housing up to the inlet manifold which may just be leaking.
Other than the inlet manifold itself this is the only way that fluid can escape on that side of the engine that I can think of, unless the water is leaking elsewhere and running along before dripping.
I keep the "transfer" pipes in stock, either Very good used or Brand New.
GTC Vert Soleil
Post by Oldconn » Fri Jan 12, 2018 9:18 am
Chris, I have a couple of sheets of gasket paper, how much(roughly) are we talking about? 3" square? :D
GTC Vert Soleil
Post by DARK STAR » Fri Jan 12, 2018 1:00 pm
Hmm, I can't actually see the leak but it is coming from the general direction of the transfer hose, which looks pretty grotty.
So I'll take one of yours thanks Mark, might as well have a new one.
Let me know how much for PayPal - have you still my address on file?
Ian, thanks but it's not leaking oil (yet) so I'll leave that for the time being.
GTC Vert Soleil
Post by gtcse8 » Fri Jan 12, 2018 1:41 pm
Hi Chris
You still at 06600?.
Will get carriage cost later today.
The pipe is only £7.
Just putting a clutch kit together for James in Aups, and have sent Ian a set of pads out for his Mini.
GTC Vert Soleil
Post by DARK STAR » Fri Jan 12, 2018 1:44 pm
Yes, still here thanks
Return to “Projects”
