Argh !!! oil pressure pipe how i hate you
maestroman
Post by maestroman » Thu Jun 26, 2014 2:44 pm
Hi all,
Just a quick rant about my SE5a. Its been off the road for nearly two years having a new wiring loom fitted ( my myself )
Its starts up, i have got a good spark, very lumpy tick over..... and i have a warm foot?? How random. :cry:
Turns out I have a slight leak on the oil pressure pipe at the gauge end. Tried to tighten it up..... and i have stripped the thread off the gauge!!! Gutted!! I am just hoping i haven`t damaged the pipe.
Not happy.
Is the oil pressure pipe ended? Or English is one end supposed to go on the gauge and one on the block? Either way i need a new gauge.
Totally and utterly gutted...........
Stephen
http://s843.photobucket.com/albums/zz351/maestroman1/
Has thanked: 132 times
Been thanked: 875 times
Re: Argh !!! oil pressure pipe how i hate you
Post by philhoward » Thu Jun 26, 2014 2:57 pm
I've had "warm leg syndrome" on mine - partly due to a lack of sealing washer on the gauge end (and a non-standard pipe due to the non-standard engine).
I've got an old plastic pipe hanging up in the garage but wouldn't put it on a car - too brittle (unless in an emergency). Got a few gauges spare though :mrgreen: as I thought I'd got a faulty one...and then looked further when the replacement also "leaked" :?
Stainless hose from the usual suspects and I can put you a gauge in the post if needed?
Post by philhoward » Thu Jun 26, 2014 2:58 pm
Oh - and don't forget to insulate the new braided hose where it goes behind the dash otherwise it might make a mess of the new loom...
maestroman
Post by maestroman » Thu Jun 26, 2014 3:15 pm
philhoward wrote:Oh - and don't forget to insulate the new braided hose where it goes behind the dash otherwise it might make a mess of the new loom...
That was what caused the loom to be replaced. Something ( the ignition light i think ) fused against the pipe and made a hole. Hot oil all over the loom and dash. Wosh, no more wiring loom. :(
The pressure pipe is new, but i bought it about 9 months ago and there is no washer on the end that attaches to the gauge. Could be my problem them? But the thread on the back of the gauge is defiantly stripped.
Thanks for the offer of the gauge. I have just replied to a wanted add, so i will see if that comes through. I am off to my parents tomorrow in Norfolk so the blokes garage is just around the corner, if he has one. Nice and simple i hope.
If not i will take you up on the offer, thanks for that.
I have also found two more tatty interior grab handles, one brown and one black if you want to add them to your collection? :lol: :lol: :lol: :lol:
Stephen
Post by philhoward » Thu Jun 26, 2014 3:19 pm
Think I've managed to make a set now on the grab handles..
Yep - should be a small (fibre?) washer which tends to live either on the end of the gauge stub or get stuck in the end of the pipe union. Miss it out = wet leg.
If you're off to close to CHG, may as well take advantage of the situation..
Post by Roger Pennington » Thu Jun 26, 2014 3:24 pm
maestroman wrote: Is the oil pressure pipe ended? Or English is one end supposed to go on the gauge and one on the block? Either way i need a new gauge.
To answer that particular question, the ends are different threads - the gauge end is the finer thread.
maestroman
Post by maestroman » Thu Jun 26, 2014 3:40 pm
Yep.... i think that is what i have done. Put it on the wrong way around.......idiot :oops:
Stephen
JoeySully
Been thanked: 34 times
Post by JoeySully » Thu Jun 26, 2014 3:41 pm
Happened me once too after removing the gauge, I ran the engine! only realised after I had run the engine for a few mins. Luckily it was nice new oil. Smell would have been much worse if it was old oil. Ended up changing the carpet and underlay anyway.
Post by Roger Pennington » Thu Jun 26, 2014 9:14 pm
Well, I've come up with a couple of photos which may help:
Here are the old pipe ends - the large one on the left is the block end (note the coarse thread) and the small one on the right is the gauge end (fine thread)
Oil Pipe - Old.jpg (113.03 KiB) Viewed 268 times
These are the new pipe ends. Looking at the large one on the left, you might easily think it was the engine end (I did, until I found the threads didn't match). In fact, looking at them close up, you can see the small one on the right has the coarse thread, and is the block end, the other end has the fine thread and is the gauge end.
Oil Pipe - New.jpg (119.09 KiB) Viewed 268 times
hylton1806
Post by hylton1806 » Thu Jun 26, 2014 10:34 pm
:oops: Hello,just noticed your comment re insulating the new pipe.What would you suggest using to insulate it.
Hylton.
My Dad said " Any fool can drive fast in a straight line its the corners that catch them out"
Has thanked: 189 times
Been thanked: 1281 times
Post by scimjim » Thu Jun 26, 2014 10:36 pm
I use heatshrink but any plastic insulator would do.
Been thanked: 56 times
Post by Elizabeth's dad » Thu Jun 26, 2014 10:38 pm
I use petrol hose cut along its length as sheathing
Post by Roger Pennington » Thu Jun 26, 2014 10:46 pm
I used this split cable sheathing (though I bought it locally).
maestroman
Post by maestroman » Fri Jun 27, 2014 9:11 am
Roger Pennington wrote:Well, I've come up with a couple of photos which may help:
Thats what i have done. I am not sure if i have stripped the thread off the pipe, but I am guessing so. I never even thought to check which end went where.
Thanks for the picture, i can clearly see the coarse and fine thread now. Bugger......
Stephen
Post by philhoward » Fri Jun 27, 2014 9:12 am
The pipe should be a steel union and the gauge is brass I think, so you might have got away with it..
