SE5A Fuel Level Warning Light Unit
tony.idle
Been thanked: 56 times
Post by tony.idle » Tue May 06, 2014 11:33 am
I'm trying to finish off an article for Slice describing the operation of The Fuel gauge & Low Fuel Unit. I don't have a 5A and I can't find a spare Warning Light Unit. Could one of you kind gentlemen take a look at yours? I need the terminal designations which, if there are any, will be imprinted on the base of the unit. Associated wire colours would be handy but not essential. I'm well past the Slice contributions deadline so if you could take a look fairly quickly I'd be very grateful.
Tony
RSSOC 2332 since 1981
Been thanked: 578 times
Re: SE5A Fuel Level Warning Light Unit
Post by philhoward » Tue May 06, 2014 11:37 am
If no one beats me to it, I'll have a look tonight, Tony.
backpain
Has thanked: 26 times
Post by backpain » Tue May 06, 2014 12:36 pm
Any help john
Miss Moneypenny Coupe
Post by philhoward » Tue May 06, 2014 12:42 pm
I think he means the tin can next to the flasher units under the dash?
backpain
Post by backpain » Tue May 06, 2014 1:04 pm
Bugger ...................I will get it right had my head under that area last few days
Post by philhoward » Tue May 06, 2014 1:16 pm
I was staring at it last night wondering if to leave it there or remove it given my fuel light is now the ECU diagnostic light on mine!
Has thanked: 122 times
Been thanked: 908 times
Post by scimjim » Tue May 06, 2014 1:22 pm
pics?
Also used as a delay unit apparently?
Rimmers UKC7096
Pins:
B = battery
E = earth
L = lamp
T = tank (sender)
backpain
Post by backpain » Tue May 06, 2014 1:27 pm
Another pic
Post by philhoward » Tue May 06, 2014 1:45 pm
I for Ignition sounds right
backpain
Post by backpain » Tue May 06, 2014 1:51 pm
E for :D Black wire
tony.idle
Post by tony.idle » Tue May 06, 2014 2:03 pm
Thanks all. I have to have the article in today so your efforts are much appreciated. Might use that photo too!
Tony
Post by scimjim » Tue May 06, 2014 2:07 pm
Just read a thread on a stag site - the unit is basically just a delay - they add it to stop the low fuel light flashing on corners at 1/4 tank full.
Post by philhoward » Tue May 06, 2014 2:32 pm
Would be a worthy addition to a 6 series...
Post by scimjim » Tue May 06, 2014 3:21 pm
Which uses the same system (inc warning lights) as a stag :-)
The unit isn't actually a low level warning unit at all is it Tony? The sender indicates low fuel, this just stops it flashing all the time.
Post by philhoward » Tue May 06, 2014 3:43 pm
On a 5a, this uses the voltage (resistance) value - it's actually a miniature bimetallic gauge of its own with a "make" setting. Add in the hysteresis of the Smiths bimetallic system, and thats how it doesn't flash on and off like a devil like the float mounted version.
