Sabre Turbo racer: 'Light Sabre'
Has thanked: 390 times
Been thanked: 324 times
Post by CNHSS1 » Wed Oct 16, 2019 11:06 pm
CDS Tube for upper wishbones arrived, new rosejoints, and threaded inserts. Some brackets for the splitter mounts, 6mm Cap screws, hoping to get on tomorrow night. Fingers crossed the correct discs arrive before the weekend too
Has thanked: 162 times
Been thanked: 92 times
Post by efi_sprintgte » Thu Oct 17, 2019 6:53 am
8)
Has thanked: 271 times
Been thanked: 220 times
Post by Corky » Thu Oct 17, 2019 3:32 pm
CNHSS1 wrote:
Wed Oct 16, 2019 11:03 pm
Go hard or go home, never been one to make up the numbers, win it or bin it! 8)
Or do both :lol:
Post by CNHSS1 » Thu Oct 17, 2019 10:46 pm
Tonights progress
Thanks to BC Flat Hat and Couchie B for the company, banter and not complaing when i burnt BC with the welder... :oops:
Correct discs arrived today :-)
Been thanked: 119 times
Post by BigBobPilot » Thu Oct 17, 2019 11:40 pm
From the proposal that is sketched out in the dust on the windscreen, I'm trying to work out what the original problem was? Something to do with hungry caterpillars maybe?
There are a few removable things welded together, the struts back from the front armature, to the original chassis cross-member might make it all tricky to unbolt in one lump? Might a bolted plate doubled up on the top armature bolt give the same bracing, but with easier servicing?
SS1 CA18DET race car
Post by CNHSS1 » Thu Oct 17, 2019 11:48 pm
Plan is all to be removable, from crossmember forwards. Couple of round tubes are to hold from armature br in location. Will have boltable flanges 👍
Has thanked: 155 times
Been thanked: 136 times
Post by b.c.flat hat » Fri Oct 18, 2019 9:07 am
Flux magnetron or witch-craft, they're all in his tool box.
Post by CNHSS1 » Fri Oct 18, 2019 9:55 am
Ask BC what the hyroglyphs on the screen are about :lol:
His work, not mine :wink:
Post by b.c.flat hat » Fri Oct 18, 2019 12:53 pm
Half front view of a Lockheed Hercules showing where I travelled when the crew door blew open during a pressurisation test. The wiggly line indicates where I bounced and came to rest. Some compies say the blows sustained during my unauthorised flight accounts for my driving style.😁😎
Has thanked: 296 times
Been thanked: 148 times
Post by MikeyBikey » Fri Oct 18, 2019 2:19 pm
That would imply there was something in there previously ?
Post by BigBobPilot » Fri Oct 18, 2019 3:18 pm
Ah, it all becomes clear, on both counts.
Has thanked: 26 times
Been thanked: 150 times
Post by gtcse8 » Fri Oct 18, 2019 6:20 pm
Flat caps have their uses, Fred Bibnah used his as welding gloves, amongst other`s.
Brian obviously used his as PPE for his bonce, but I don`t think it would be up to PPE at work 1982 regs, especially when bouncing arse over tit out of a plane.
:bh much like this.
Any comment from Steve C on this subject :?: :lol:
EX SST 1800Ti
Post by CNHSS1 » Fri Oct 18, 2019 8:48 pm
Severe blows on head years ago does explain BCs love of GTEs... :barf: :mrgreen:
Post by CNHSS1 » Mon Oct 28, 2019 12:56 pm
Some new rear brackets to convert trailing arms to diacs and calipers
Dcrosby13
Has thanked: 22 times
Been thanked: 67 times
Post by Dcrosby13 » Mon Oct 28, 2019 1:16 pm
What calipers are you thinking of using?
I break stuff...... :w
