Heated Screens
Re: Heated Screens
Post by toomanysabres » Sat Nov 28, 2015 9:37 pm
It doesn't matter which way the current flows so I joined the two 'inner end wires' and fed power to one outer and earth to the other. But wait till I have spoken to Ricky.
Has thanked: 224 times
Been thanked: 52 times
Re: Heated Screens
Post by willholderogri » Sun Nov 29, 2015 12:04 pm
I believe they are supposed to be in parallel on the SE5A that is how it is described on the instructions on the ricky evans website when I bought mine
Last edited by willholderogri on Sun Nov 29, 2015 12:09 pm, edited 1 time in total.
Re: Heated Screens
Post by willholderogri » Sun Nov 29, 2015 12:08 pm
just looked again as I bought mine a while ago and the web page has changed the diagram is clear enough but it does not refer to the two sides. unlike his previous instructions (back to ricky for clarification I would say)
Re: Heated Screens
Post by toomanysabres » Sun Nov 29, 2015 12:11 pm
My Coupe one is the same obviously. So maybe the series connection recommendation was for the Sabre one. As I said I will be double checking.
Maybe the advice has changed on experience or feedback.
Merlin
Re: Heated Screens
Post by Merlin » Sun Nov 29, 2015 5:45 pm
Yes do let me know. It could simply be related to screen height. For screens that have a limited depth connecting in series increases the resistance path, hence lowers the current draw and prevents overheating. Not aware myself the difference in height of screens se5a cf sabre (although the difference could be se5 / sabre cf. a more modern car and that the instructions are for the more modern car).
Re: Heated Screens
Post by willholderogri » Sun Nov 29, 2015 6:33 pm
just read the instructions properly this time it does say it should have one relay per side so the two sides are not physically connected together (so not series) for their larger two element screens
Re: Heated Screens
Post by toomanysabres » Sun Nov 29, 2015 7:42 pm
Merlin wrote:Yes do let me know. It could simply be related to screen height. For screens that have a limited depth connecting in series increases the resistance path, hence lowers the current draw and prevents overheating. Not aware myself the difference in height of screens se5a cf sabre (although the difference could be se5 / sabre cf. a more modern car and that the instructions are for the more modern car).
That is what I thought earlier. 5 & Coupe = 21.5", Sabre = 16" compared to my BMW which is 32" although a big car is more upright than many more raked moderns.
Has thanked: 130 times
Been thanked: 871 times
Re: Heated Screens
Post by philhoward » Sun Nov 29, 2015 8:11 pm
I think the aspect ratio has something to do with it?
The worst that will happen is that it takes a bit longer to clear the screen if connected in series. Surely better than melting it! SS screens are much closer to modern screens so only have a single pair of connections from memory?
Has thanked: 186 times
Been thanked: 1264 times
Re: Heated Screens
Post by scimjim » Sun Nov 29, 2015 8:14 pm
glanced at mine today (still in the packaging) and there's a connection either side - not sure if that's one wire each side or two though?
windy
Been thanked: 41 times
Re: Heated Screens
Post by windy » Sun Nov 29, 2015 8:30 pm
If you can find out what wattage the elements are designed to safely dissipate then its simple to work out which configuration to wire them in.
Has thanked: 375 times
Been thanked: 265 times
Re: Heated Screens
Post by Corky » Sun Nov 29, 2015 8:44 pm
Yes, just two connections on the small sports screens.
Re: Heated Screens
Post by scimjim » Sun Nov 29, 2015 8:47 pm
Corky wrote:Yes, just two connections on the small sports screens.
on either side at the bottom corners?
Re: Heated Screens
Post by scimjim » Sun Nov 29, 2015 8:57 pm
I bought a timer relay from a London taxi for Megan 3 - as I won't have a red low coolant relay next to the yellow low fuel relay, I thought this fitted in well :-)
timer relay.JPG (112.26 KiB) Viewed 3996 times
Re: Heated Screens
Post by Corky » Sun Nov 29, 2015 8:57 pm
From memory...... Yes
I think there's a photo on my DET thread.
gordini5
Has thanked: 21 times
Re: Heated Screens
Post by gordini5 » Sun Nov 29, 2015 9:27 pm
scimjim wrote:glanced at mine today (still in the packaging) and there's a connection either side - not sure if that's one wire each side or two though?
On my 5a screen sitting in the garage there are two pairs wires, one at each lower corner. All are black, have just marked the end of two of them incase I get them mixed up after fitting.
