Move to New Server
Can't register?
Ian
Been thanked: 54 times
Move to New Server
Post by Ian » Mon Jul 11, 2011 8:35 am
ScimitarWeb, including this Forum, is going to be moved to a new server on Thursday 14th July 2011.
I plan to start the work at 06:00 and expect it to take several hours. Please do not make posts close to this time as they may get lost in the process.
The new server gives us greater control over the resources used by ScimitarWeb and should help prevent problems like the one that took the site down several times earlier in the year. It will also provide a more robust platform for future developments of the site such as an online archive and the provision of sites for noggins.
Please bear with us while these changes are made and please report any of the inevitable glitches that you may discover.
Ian
ScimitarWeb WebMaster
RSSOC 453
Ian
Re: Move to New Server
Post by Ian » Thu Jul 14, 2011 6:13 am
The move has started and the board is disabled
Ian
RSSOC 453
ScimitarMatt
Post by ScimitarMatt » Thu Jul 14, 2011 12:54 pm
Here's an odd thing Ian, I've just tried searching for something and got no results, so I tried searching for 'scimitar' and this is what I got -
No posts were found because the word scimitar is not contained in any post.
any ideas why this is? cheers, Matt
http://www.scimitargt.co.uk
coupe.registrar@rssoc.co.uk
PLEASE NO PM'S, EMAIL ME
Ian
Post by Ian » Thu Jul 14, 2011 1:00 pm
Matt,
In order to make the move we have to drop the search indexes because they are so large. The search indexes will be regenerated shortly.
Ian
RSSOC 453
ScimitarMatt
Post by ScimitarMatt » Thu Jul 14, 2011 1:18 pm
fair enough, just wasn't sure if it was a technical fault or a planned bit of cunningness ;)
Been thanked: 119 times
Post by ScimmyMike » Thu Jul 14, 2011 2:22 pm
Blimey, it's a bit quicker that I'm used to, great job by Ian and the team, thanks,
Mike
Has thanked: 188 times
Been thanked: 188 times
Post by Corky » Thu Jul 14, 2011 2:30 pm
I'll second that. Well done !
I'll have to learn to read faster to keep up with the new pace..
Ian
Post by Ian » Thu Jul 14, 2011 5:01 pm
The forum search index has just finished its work. The search facility for the forum should now be fully operational.
Ian
RSSOC 453
Has thanked: 137 times
Been thanked: 508 times
Post by Roger Pennington » Thu Jul 14, 2011 7:38 pm
scimitarcars.org.uk wrote:I'll second that. Well done !
If you're going to become a compie you'd better get used to trying to shave fractions off your previous best time :lol:
On a more serious note, well done Ian, it does indeed seem to be up and running much faster than before! :D
JoeySully
Been thanked: 30 times
Post by JoeySully » Thu Jul 14, 2011 8:18 pm
yes much faster - i have noticed that I dont stay logged in though. I have a bookmark for "view unread posts" and it asks me to log in every time I click it even if I select the log me in automatically option. Im running XP and Firefox
EDIT maybe im wrong it seems to have stopped doing it now :oops:
Ian
Post by Ian » Thu Jul 14, 2011 8:27 pm
It's been happening to me too! I think the sessions and the cookies have got out of step. Deleting all the board cookies (link at bottom right) might be a good idea.
Ian
RSSOC 453
roymck
Has thanked: 15 times
Been thanked: 24 times
Post by roymck » Thu Jul 14, 2011 8:31 pm
And me to , locked out , but deleted cookies and i am back in .. Roy
Post by Roger Pennington » Thu Jul 14, 2011 8:31 pm
Hi Joey, I use shortcuts for "View Unread" "View new" and "Index Page" ("View Unread" being the one I use most) and I found I had to regenerate them all - the old ones seemed to assume I wasn't logged-on on the new server. Once regenerated they seem fine.
Hope that helps,
demonbluedays
Post by demonbluedays » Thu Jul 14, 2011 9:09 pm
and now i'm finally able to get in (ta for that peoples!) it's a greased up deaf guy (watch family guy, you'll understand) in comparison to the old server!
Tom "DemonBlueDays" Williams
1976 SE6 #141 "Mighty"
2009 Fox "King"
Former Owner Of
erikscimitardemon
Been thanked: 21 times
Post by erikscimitardemon » Fri Jul 15, 2011 10:00 am
Ian,
I posted this after the change over. A picture was attached to this post. It was visible first, but now it has vanished. Is the pictures/posts out of sync?
Erik Hofman
http://www.scimitar.demon.nl
