Roadgoing silhouette
Benc
Has thanked: 100 times
Been thanked: 60 times
Post by Benc » Sat Nov 02, 2019 5:59 pm
As above in roadgoing can the front & rear wings be spaced out to fit wider tyres under the arches?
Has thanked: 167 times
Been thanked: 1174 times
Post by scimjim » Sat Nov 02, 2019 7:46 pm
I’d say no - although I’ll admit to a little tweak on the rear arches with a hair dryer :D
11.4.1. Silhouette of the vehicle must remain unaltered in construction, dimension and material. The silhouette will be taken in the condition in which the car competes (convertible closed cars competing with the hood or top not erected shall have the silhouette determined in that condition).
11.4.2. Engine bonnet/cover and luggage/boot cover may be replaced with an alternative material.
11.4.3. Laminated windscreens permitted but all other glass may not be replaced by another material.
11.4.4. Deleted. 11.4.5. Deleted.
11.4.6. Interior trim must remain fitted (except floor carpets/mats).
11.4.7. All working equipment fitted as standard (heater, window mechanisms, sunroof, door handles) must remain operable at all times.
Benc
Post by Benc » Sat Nov 02, 2019 8:18 pm
I’d say no - although I’ll admit to a little tweak on the rear arches with a hair dryer.....
Yes then🤔
Post by scimjim » Sat Nov 02, 2019 11:15 pm
Not “spaced out” like batmobile was.
Has thanked: 106 times
Been thanked: 806 times
Post by philhoward » Sat Nov 02, 2019 11:23 pm
As above, no - but nothing to say you can’t make the inner arches wider instead?...
Has thanked: 341 times
Been thanked: 243 times
Post by Corky » Sun Nov 03, 2019 9:50 am
There are plenty of RG cars out there with widened arches or wearing JDM style extensions. Peter’s car has spaced wings and entered as RG without any issues.
Strictly legal or not, scrutes don’t seem too bothered.
Been thanked: 70 times
Post by Nick » Sun Nov 03, 2019 9:51 am
Are you at the stage where it is worth considering going Mod Prod? .
Dcrosby13
Has thanked: 35 times
Been thanked: 105 times
Post by Dcrosby13 » Sun Nov 03, 2019 11:59 am
How wide can they be made in modprod?
I break stuff...... :w
Post by scimjim » Sun Nov 03, 2019 12:04 pm
Bodywork (including aerofoils)
12.5.1. Silhouette of the vehicle as seen in side elevation must remain unaltered, with the exception of engine bonnet/cover and boot lid/rear deck.
12.5.2. The doors, engine, bonnet/cover, luggage compartment cover, boot lid/rear deck or bodywork not forming part of the unitary construction may be changed for ones of different material. Wheel arch extensions are free.
12.5.3. Alternative materials may be used for external mudguards, if attached by bolts and/or rivets.
12.5.4. Detachable hardtops are permitted providing the silhouette remains unaltered.
12.5.5. Plastic is permitted for side and rear windows. A hole approximately 15cm diameter may be cut in the window next to the driver for signalling or ventilation.
12.5.6. Demisting apertures are permitted in the rear window. They must be in the form of holes or slots and be positioned close to the top or sides, but not both.
12.5.7. Open car with hoods may have them removed. Vehicles may run open or closed. If running closed, a rear window of safety glass or plastic of minimum thickness 4mm is mandatory.
12.5.8. Tonneau covers are permitted providing they are of flexible material and were originally specified for the vehicle.
12.5.9. It is prohibited to cut holes in any panel unless specifically permitted.
12.5.10. Front spoilers/air dams/splitters are permitted below the level of the road wheel centres, up to 15cm beyond the overall plan periphery of the existing bodywork, excluding bumpers. Rear spoilers are permitted within the overall plan periphery of the original vehicle excluding bumpers. A rear spoiler is a raised surface of opaque material integral with the rear deck with no gaps or openings in the surface, front or rear, and not exceeding half the vertical height of the original rear window fitted into the vehicle, measured at the centre of the original window. The vehicle manufacturer’s original equipment or a specified option for that vehicle is also permitted.
12.5.11. Deleted.
12.5.12. It is permitted to remove the floor carpets, underfelt, sound insulation throughout the car, the rear seat, the passenger’s front seat and the head lining.
12.5.13. It is permitted to carry out modifications to window winders, instrument panels and all driving controls.
Benc
Post by Benc » Sun Nov 03, 2019 3:51 pm
Thought so Steve.... if it's good for the comp sec etc
Just need some 13" wheels now
Has thanked: 39 times
Been thanked: 51 times
Post by nickkeyser » Sun Nov 03, 2019 4:09 pm
Is this to fit slicks?
SSSC Champion 2019
SS1 CVH 1600Ti
Benc
Post by Benc » Sun Nov 03, 2019 4:26 pm
My plan is to run 1b tyres in 2020.
But if I modify the car to take wider tyres I only want to do it once.
What size did you run Nick this year?
I am thinking either Extreme or Avons based on what I've seen :D
If I do modify to take 13 in a wide width I might try a track day with some slicks to see the difference maybe at Tycroes
Post by philhoward » Sun Nov 03, 2019 4:33 pm
Wasn’t/doesn’t the ex-King/Oakes/Cork running rather wide 13’s with just some JDM extensions?
I’ve got a pair spare in my garage if you want to have a play?
Post by swoakes » Sun Nov 03, 2019 4:57 pm
You mean the King-Cork-Oakes-Cork Sabre :)
Yes we had 13's on that. Spacers on front and no issues with rear arches which remained as standard as far as I can remember. Certainly no extensions.
SS1 arches will need a tweek based on Corky fitting 13's to the DET.
Edit
Photo below of rear arch from Corky's thread which looks standard :?:
Post by philhoward » Sun Nov 03, 2019 5:34 pm
I was basing it on the pics of it up for sale recently..but yes, that Sabre that’s got a rather long list of multiple ownership..
