Harness regulations
Has thanked: 33 times
Been thanked: 420 times
Re: Harness regulations
Post by philhoward » Tue May 07, 2013 2:42 pm
Theoretically the e mark is a construction and use regulation - but depends on the mot tester?
SS1's - 1600 Rooster Turbo; Sabre Mk1.5
SE5a Barn Find Project 24 Valve conversion
Previous: SE5/5a/SS1 No.1/SS1 Rooster/SS1 1800Ti
Been thanked: 47 times
Post by swoakes » Tue May 07, 2013 2:53 pm
I have ordered the red securon 4 point harnesses that are e marked with 50mm straps.
Post by nickkeyser » Tue May 07, 2013 5:07 pm
Sorry if its been said already, but do the roadie class regs require E marked or FIA approved?
Been thanked: 162 times
Post by CNHSS1 » Tue May 07, 2013 5:34 pm
no idea, would assume E marked as FIA is a sporting body rather than safety body
Post by swoakes » Tue May 07, 2013 5:47 pm
The blue book says belts must be from a recognised manufacturer and fitted as per instructions. No mixing of belts from different systems to one seat. FIA approved for international events only. No mention of E marked but that may be a requirement for MOT :?:
A local company is selling 4 point harnesses for £22.99 but no markings on them so decided to go for Securon. I have 3 point Securon in the car now.
Has thanked: 92 times
Been thanked: 405 times
Post by Roger Pennington » Tue May 07, 2013 6:18 pm
swoakes wrote:No mention of E marked but that may be a requirement for MOT :?:
Regardless of whether E-marking is required for the MOT, if it's a construction & use legal requirement (not the same thing :w ) then you may need it if you're going to drive the car on the road (and be insured...... :w )
