fuel pump fuse
Been thanked: 107 times
fuel pump fuse
Post by DARK STAR » Mon Sep 23, 2019 7:01 pm
Ah, I had a fuse holder like that - it melted.
For the Ford relays, I have had to replace most of them 8)
At the moment it is the purple one which is playing up (engine management?)
The yellow one (fuel pump?) can be replaced with a standard relay (chinese, obviously) but attention! the pinout is not the same so you need to re-wire it.
Been thanked: 417 times
fuel pump fuse
Post by peter freeman » Mon Sep 23, 2019 7:21 pm
According to the MB drawing the yellow relay is fuel injector but it also energises the brown one which is for the fuel pump.
Has thanked: 64 times
Been thanked: 196 times
fuel pump fuse
Post by gtcse8 » Mon Sep 23, 2019 7:30 pm
Chris did Yorkshire Kit Cars do the conversion on Dark Star??.
fuel pump fuse
Post by DARK STAR » Mon Sep 23, 2019 7:43 pm
Yes!
It was before Don Burt took it over.
Do you know Steve Himsworth?
Peter, what does the purple relay do ?
That's the only Ford one remaining and it is playing up.
And I can't find it on the internet :roll:
fuel pump fuse
Post by peter freeman » Mon Sep 23, 2019 7:52 pm
Its not on the MB wiring diagram at all - are you sure its not just the pump fuse that Chris talked about
fuel pump fuse
Post by DARK STAR » Mon Sep 23, 2019 7:58 pm
I'll have a look tomorrow, there is certainly a fuse in it, but it's very big for a fuse holder -
and when you hit it it springs to life just like a relay :mrgreen:
Thinks 'that would explain why I can't find it on the internet ...
fuel pump fuse
Post by peter freeman » Mon Sep 23, 2019 8:00 pm
Found a Ford purple relay - its quoted as a ABS relay. https://www.classicpartsshack.co.uk/sto ... __nos.html
Has thanked: 100 times
Been thanked: 803 times
fuel pump fuse
Post by philhoward » Mon Sep 23, 2019 8:09 pm
How many wires on it, Chris? 2 = fuse. 4 or 5 = relay. Looks like a posh fuse holder to me - and likely the one that had been swapped out on Peters..
fuel pump fuse
Post by DARK STAR » Mon Sep 23, 2019 8:11 pm
Yes, I found that but it ain't the same (and I don't think I have ABS :lol: ).
Looking at photos (it's too dark in the garage) the wires are black/red so fuel pump.
I'll see tomorrow where they come from / go to and if there are any others but you are probably right it's just a fuse.
So dirty terminals ?
fuel pump fuse
Post by philhoward » Mon Sep 23, 2019 8:13 pm
Pretty likely - or the springy bit in the terminal isn’t springy enough any more.
fuel pump fuse
Post by gtcse8 » Mon Sep 23, 2019 9:35 pm
Just done a 30A fuse on a tipper truck today.
The hydraulics worked to lift the body but would not lower the load area.
The screws that held it all together were loose and the whole unit just overheated.
mark rudder
Has thanked: 30 times
fuel pump fuse
Post by mark rudder » Wed Sep 25, 2019 7:33 am
AJL, its a Scimitar, can't have quality electrics, its just not right!
Mark from down under.
Current GTE 6B, Scirocco R. Past Dolomite Sprint, XJS (manual), V12 E-type (manual, convertible, lovely) 350 chev XJ6, TR6, TR4, Sprite, Midget, local Ford V8s, others... There's a pattern here.….
Return to “Middlebridge”
