Fuse for central locking. Where?
simmit
Has thanked: 126 times
Been thanked: 8 times
Post by simmit » Mon Mar 13, 2017 5:10 pm
Subject fuse is not in the main fuse box (passenger foot well) so I assume it's in the auxiliary fuse box. But where is the auxiliary fuse box?
Been thanked: 225 times
Re: Fuse for central locking. Where?
Post by AJL Electronics » Mon Mar 13, 2017 5:16 pm
Have a look in the passenger footwell, on the firewall.
Been thanked: 339 times
Post by peter freeman » Mon Mar 13, 2017 5:19 pm
If you lie on your back in the foot well you can see a few fuses behind the glove box - easier to take the glove box out to access them. If I remember rightly its the one nearest the centre console - took mine out as it flattens the battery if you don't use the car regularly. Anyway look for the brown and orange wires either side of it.
simmit
Post by simmit » Mon Mar 13, 2017 5:55 pm
Thank you gentlemen. I would not have found it without your help.
On MB50 the fuse box is discovered on the bulkhead/ firewall and rather cleverly is completely hidden by under dash/ glove-box upholstery trim panel. 10 out 0f 10 to the hide and seek merchants at Middlebridge who thought it would be a laugh!
Incidentally, the trim panel seems not to be secured in any way other than it's a tight fit at the sides and thus rendering it further impossible to fit it above the auxiliary fuse box. Brilliant!
Return to “Middlebridge”
