Weight
Been thanked: 319 times
Weight
Post by peter freeman » Thu Mar 09, 2017 5:36 pm
Anyone off the top of their head know the weight of the MB. Had mine in for its MOT today ( passed with no advisories ) but he asked how heavy the car was. The nearest we could find on his pc was a 6 which I think is lighter.
scimmy_man
Been thanked: 32 times
Re: Weight
Post by scimmy_man » Thu Mar 09, 2017 5:41 pm
the rollers giveyou an axle weight.
Re: Weight
Post by peter freeman » Thu Mar 09, 2017 5:46 pm
The car was finished its MOT and out in the car park by the time the weight was asked.
Has thanked: 77 times
Been thanked: 54 times
Re: Weight
Post by efi_sprintgte » Thu Mar 09, 2017 6:05 pm
1400kg rings a bell. Thinking back to when we corner weighted one.
Re: Weight
Post by peter freeman » Thu Mar 09, 2017 6:09 pm
I've looked on the web and the weight varies between 1288 and 1680 kg ???
Been thanked: 66 times
Re: Weight
Post by Scimher » Fri Mar 10, 2017 12:27 am
Congrats. on the MOT, Peter - my old 5 failed hers on Tuesday.........not by much - neither brake lights worked (am sure they had been okay but there was a prob. with a dipped headlight & then a front indicator, so maybe that had something to do with it!) & a frayed passenger seatbelt (which I've removed & dropped into a local webbing company. I should be able to pick up the new section tomorrow morn., fit it & get the ticket for the weekend...My pal Andy traced the brakelight problem to the bulbholders - now working again. Sidelights were okay & both filaments were intact in the bulbs so I assumed that there was no problem there...
Re: Weight
Post by peter freeman » Fri Mar 10, 2017 9:14 am
I was very surprised that on the rear brake test the handbrake was better than the foot brake. I have always thought that the handbrake was not good enough as unlike the other scims we have had or do have that I cannot lock the back wheels with the handbrake. Both it seems still good enough to pass the MOT.
Re: Weight
Post by Scimher » Fri Mar 10, 2017 9:55 am
...I didn't think my handbrake was good enough, either, to be honest...but it passed...
Re: Weight
Post by peter freeman » Fri Mar 10, 2017 2:23 pm
Our MOT station has had a major burnout - caused by electricians getting the wiring wrong when the garage was extended. So all the brake testing equipment is new - and not as good. He cannot test the balance with the new stuff so he has to use his experience to judge it - all to my advantage he laughingly said - I did not complain.
Re: Weight
Post by Scimher » Sat Mar 11, 2017 2:43 pm
...My local garage has a new purpose-built building with state-of the-art brake testing equipment....in fact he congratulated me on the performance of the brakes - I assume he meant footbrake. I've mentioned this before but the chap who tested mine is a long-time owner of a red SE5a so knows what to look for....so when an advisory said 'slight wear in both front wheel bearings', I have to assume that he knows that there should be a little play & this is extra...
Re: Weight
Post by DARK STAR » Sun Mar 12, 2017 8:00 pm
Weight according to Middlebridge 8)
1266 - 1311 kg according to options fitted
Re: Weight
Post by peter freeman » Sun Mar 12, 2017 8:13 pm
I'm not sure which weight they go by - is it the kerb weight ( as Chris lists ) or the gross weight which is 1680kg.
Been thanked: 534 times
Re: Weight
Post by philhoward » Sun Mar 12, 2017 9:14 pm
For a brake test then it should be kerb (or service) weight which is pretty close to the weight when they test it.
Return to “Middlebridge”
