Tyre pressures
mikeyb1
Tyre pressures
Post by mikeyb1 » Wed Sep 25, 2019 11:22 am
I have 165/80x15 tyres on my Coupe. If you are using the same size tyres, can you tell me what pressures you use? Can't find any info anywhere! Thanks, Mike.
Has thanked: 167 times
Been thanked: 1174 times
Tyre pressures
Post by scimjim » Wed Sep 25, 2019 11:54 am
Owners handbook.
Tyre pressures
Post by Old and Slow » Wed Sep 25, 2019 1:23 pm
I use 26 all round on the Sabre Six, same size radial tyres too.
Been thanked: 417 times
Tyre pressures
Post by peter freeman » Wed Sep 25, 2019 1:25 pm
I use 26 as well - on all of our cars
Has thanked: 341 times
Been thanked: 243 times
Tyre pressures
Post by Corky » Wed Sep 25, 2019 4:51 pm
I wouldn’t use the same on all of mine. The SS1 with Rainsports needs about 28psi on the road or the soft tyre wall is unbearable (26psi when sprinting), Touareg needs 34 psi all round or 36F/44R when towing, S2000 needs 34psi or it handles like a boat.
Tyre pressures
Post by peter freeman » Wed Sep 25, 2019 5:17 pm
All of our cars are Scimitars of one kind or another Corky - the SS1 and Sabre feel fine on Rainsports at 26psi - our shocker settings are not the same as yours as I found out when I first got your SS1
mikeyb1
Tyre pressures
Post by mikeyb1 » Wed Sep 25, 2019 6:53 pm
Thanks for all the replies folks, 26 it is then.
Tyre pressures
Post by DARK STAR » Wed Sep 25, 2019 8:26 pm
I have lower profile tyres (195-65x5) and run 32 front, 30 rear for what it's worth.
If the handbook pressures are as accurate as their tank capacity figures I wouldn't take much notice - 21,25 gallons is actually 96,6 litres :roll:
Tyre pressures
Post by DARK STAR » Wed Sep 25, 2019 8:27 pm
and 26 lb = 1,79 bar !
Tyre pressures
Post by scimjim » Wed Sep 25, 2019 8:33 pm
And 26psi is 1.828 kg/cm2.
Tyre pressures
Post by DARK STAR » Wed Sep 25, 2019 9:11 pm
Isn't a bar the same thing as a kg/cm2 :?:
Tyre pressures
Post by scimjim » Wed Sep 25, 2019 9:33 pm
Not quite, a bar is 100,000 Pascals but ISA atmospheric pressure is 101,325 Pascals.
Tyre pressures
Post by DARK STAR » Wed Sep 25, 2019 9:43 pm
Good grief :shock:
I won't ask why.
I doff my cap to my learned friend ...
Has thanked: 106 times
Been thanked: 806 times
Tyre pressures
Post by philhoward » Wed Sep 25, 2019 9:48 pm
Don’t get me started - wasted 20 minutes of my life today trying to find out exactly why a customer insisted his pressure sensors needed to be calibrated in mwg (metres water gauge) instead of something sensible like bar.
It is a water pumping station, so he had a point.
Tyre pressures
Post by scimjim » Wed Sep 25, 2019 11:24 pm
Aviation uses bars (or millibars) because meteorologists use them - apparently they were invented by a Norwegian meteorologist.
Return to “Coupé”
