Ignition switch Wiring
backpain
Has thanked: 26 times
Post by backpain » Thu Mar 15, 2018 11:30 am
Need some advise to cut a long story short ,,when I turn on my ignition switch not to start it but just on its dead .
I have followed 12v from battery all way to ignition switch but as soon as I turn it on the volts drop to 1point something ,there are lots of new parts starter( high torque),,relay,,ignition switch,
I have looked at all of it many times ,is it down to poor wires connections etc thanks john
Miss Moneypenny Coupe
Been thanked: 86 times
Post by Coupe Racing » Thu Mar 15, 2018 8:11 pm
Sounds like a wire on a wrong terminal
Been thanked: 319 times
Post by peter freeman » Thu Mar 15, 2018 8:21 pm
Been thanked: 840 times
Post by scimjim » Fri Mar 16, 2018 7:21 am
Which way are you turning it? Not sure if you’re aware or not but the coupe isn’t off/acc/run/start (L to R) like normal switches, it’s acc/off/run/start
backpain
Post by backpain » Fri Mar 16, 2018 8:38 am
Thanks guys ,will have a close look this morning its no doubt down to me I seem to be making mistakes as I get older :lol:
Post by scimjim » Fri Mar 16, 2018 11:03 am
IIRC Steve B’s (gillsfan) early SE5 “rat-rod” had a dash mounted switch and it threw me when you had power if you put the switch fully anti-clockwise but then no power on the next click clockwise (with the key vertical) :D
backpain
Post by backpain » Sat Mar 17, 2018 8:27 am
Interesting ,,,What happens when I switch on ignition does it just pass on 12v to the other 3 wires?
I had a good look I cannot see wrong connection etc but still it drops to 1v when ignition on , and now its snowing again
Post by peter freeman » Sat Mar 17, 2018 8:50 am
Where exactly are you measuring 1 volt.
backpain
Post by backpain » Sat Mar 17, 2018 10:11 am
With the ignition off I have 12v ish at switch /ammeter /solenoid /starter. That's as it should be I think,but when I switch ignition on the volts drop to around 1v on all locations .
This started a couple of weeks ago I suspected the starter its new low torque one so I was asked to send it back for testing which I did,,, no fault found tested twice
I think I will remove starter and see results,,, after a cuppa
Post by peter freeman » Sat Mar 17, 2018 10:31 am
I think you should go back a step - check the voltage at the battery terminals and the switch with it on and off then disconnect one wire at a time on the outgoing side of the switch. I would also check that the battery terminals are clean and tight.
Post by scimjim » Sat Mar 17, 2018 5:53 pm
Are you sure it’s not just a dodgy main battery earth?
backpain
Post by backpain » Mon Mar 19, 2018 4:33 pm
Well what can I say I did take a step back and to the battery earth lead which I bypassed with jump leads and it all came to life :o ,never did I think it was the earth lead I had the body off in summer it was all clean .
Thanks for help guys ,next step starting her
Been thanked: 534 times
Post by philhoward » Mon Mar 19, 2018 4:36 pm
Well done :D
Post by peter freeman » Mon Mar 19, 2018 5:18 pm
A small cup of petrol down the carb throat always helped things along for me
Return to “Coupé”
