Ti starting
Dave Eddy
Ti starting
Post by Dave Eddy » Thu Feb 14, 2019 1:16 pm
Mine has 2 rivets thru it so doesn't appear to clip open, dare not get to forceful with it in-case i smash it.
PeteMac
Has thanked: 29 times
Ti starting
Post by PeteMac » Thu Feb 14, 2019 1:30 pm
Have you tried adjusting it? Two screws hold it in place: one above and another below. Once slackened a little, it can be rotated for adjustment. There should be continuity in the idle position, and continuity should break as soon as the throttle is opened. (That's how I set mine up anyway.)
1987 1800Ti
(previous 1975 SE5a, 1968 GT)
Has thanked: 415 times
Been thanked: 348 times
Ti starting
Post by CNHSS1 » Thu Feb 14, 2019 1:36 pm
I may have a spare, will check tomorrow
Dave Eddy
Ti starting
Post by Dave Eddy » Thu Feb 14, 2019 5:31 pm
Yes tried adjusting it, didn't seem to get much just very slight rpm change but on testing it has No Continuity reading at any position ,think i may have sourced a working used one.
Dave Eddy
Ti starting
Post by Dave Eddy » Sat Feb 16, 2019 8:15 pm
RESULT, just fitted a new fuel regulator and BINGO, it starts, not sure why, Don't really care as long as it starts and runs. left it now overnight , proof of the pudding in the morning to see if it starts ??
Has thanked: 152 times
Been thanked: 1038 times
Ti starting
Post by scimjim » Sat Feb 16, 2019 8:21 pm
Excellent :D
Has thanked: 282 times
Been thanked: 224 times
Ti starting
Post by Corky » Sat Feb 16, 2019 8:27 pm
Fingers crossed you’ve fixed it 8)
PeteMac
Ti starting
Post by PeteMac » Sat Feb 16, 2019 9:19 pm
Great news! It’s a great feeling when it finally bursts in to life.
1987 1800Ti
Dave Eddy
Ti starting
Post by Dave Eddy » Mon Feb 18, 2019 11:27 am
Well guys, Ive put away the HAMMER (for now!) as my car started this morning, I adjusted the NEW regulator pressure last night to what the Bluebird manual suggested which is 43psi,actually set it at 40,dont know why,Probs cos to much pressure worries me a little, does anybody have any other pressure settings suggestions/recommendations. i'm gonna let the dust settle for a few days, start eating and sleeping again and maybe go outside of the garage and see my family again! HAA
See if it starts next week ! ???
Thanks to all
No-Doubt back soon.
hermeticist
Has thanked: 35 times
Ti starting
Post by hermeticist » Mon Feb 18, 2019 11:08 pm
Can I ask: what fuel regulator did you get (have I missed the post!?), I understand you have to cut the rail to replace it?
Dave Eddy
Ti starting
Post by Dave Eddy » Tue Feb 19, 2019 8:47 am
Got a Malpassi fuel regulator(for injection) £89 , No cutting of the rail as the regulator is joined into return line at out feed of the rail, spliced into the rubber pipework .
Malpassi / FSE Sytec AIR004 Adjustable Fuel Pressure Regulator 1-5 bar & Gauge, E-bay.
hermeticist
Ti starting
Post by hermeticist » Tue Feb 19, 2019 8:50 am
Hi Dave, thanks for that, I think I might give it a try!
Ti starting
Post by CNHSS1 » Tue Feb 19, 2019 11:30 am
Have you left the OEM regulator in the rail as well?
Dave Eddy
Ti starting
Post by Dave Eddy » Tue Feb 19, 2019 12:00 pm
No integral regulator on my rail, maybe removed by previous owner ?? a malpassi was already fitted so just a case of ,one off, one on !
Ti starting
Post by CNHSS1 » Tue Feb 19, 2019 12:59 pm
Ah, ok, just checking :wink:
