Nissan ECU part numbers
Has thanked: 113 times
Been thanked: 750 times
Post by scimjim » Mon Dec 16, 2013 10:16 am
On this page you find a list of all the supported Nisssan ECU’s.
On every Nissan ECU there is a sticker with numbers and codes.
The number that is common to all ECU’s is 23710-.
This is then followed by 2 numbers 2 letter and 2 numbers.
If you find this code on your ECU and then look in the left had column below you will then be able to see
which NIStune board you require.
NISSAN 23710- VEHICLE ID (ADDRESS FILE) BOARD TYPE ADAPTOR/NOTES
94LXX A31_RB20 Not supported
2M0XX B14_SR20DE_95_96 Not supported
72LXX C33_RB20DE Not supported
2N5XX N16_SR16VE Not supported
85FXX S15_SR20DE Not supported
72LXX A31_RB20 Type 1
73L0X A31_RB20 Type 1
73L1X A31_RB20 Type 1
73L6X A31_RB20_LATE Type 1
73L7X A31_RB20_LATE Type 1
71LXX A31_RB20_LATE Type 1
5L2XX A31_RB20_LATE Type 1
J71XX CR31_RB30 Type 1
21BXX EK10_MA09ERT Type 1
58SXX HR31_RB20DET_EARLY Type 1
59SXX HR31_RB20DET_EARLY Type 1
80SXX HR31_RB20DET_LATE Type 1
805XX HR31_RB20DET_LATE Type 1
45LXX HR31_RB20DET_LATE Type 1
76SXX HR31_RB20ET Type 1
87EXX J30_VG30E Type 1
98EXX J30_VG30E Type 1
85MXX KN13_CA16 Type 1
28MXX N12_E15ET Type 1
82MXX N13_CA16 Type 1
02YXX N13_CA18 Type 1
R22XX R30_RJ20DET Type 1
30FXX S12_CA18 Type 1
35FXX S13_CA18 Type 1
36FXX S13_CA18 Type 1
39FXX S13_CA18 Type 1
44FXX S13_CA18 Type 1
42FXX S13_KA24E Type 1
B49XX VLT_RB30 Type 1
01PXX Z31_EARLY_VG30 Type 1
06PXX Z31_EARLY_VG30 Type 1
10PXX Z31_EARLY_VG30 Type 1
02PXX Z31_EARLY_VG30 Type 1
21PXX Z31_LATE_VG30 Type 1
06PXX Z31_LATE_VG30 Type 1
25PXX Z31_LATE_VG30 Type 1
545XX Z31_LATE_VG30 Type 1
26PXX Z31_LATE_VG30 Type 1
18PXX Z31_MID_VG30 Type 1
64UXX Q45_VH45DE_91_93 Type 2
71UXX Q45_VH45DE_91_93 Type 2
66UXX Q45_VH45DE_91_93 Type 2
05UXX BNR32_RB26 Type 2
08UXX ECR32_RB25DE Type 2
01UXX HCR32_RB20 Type 2
04UXX HCR32_RB20 Type 2
11UXX HCR32_RB20 Type 2
F66XX M30_VG30 Type 2
0J3XX P10_SR18DE Type 2
70J8X P10_SR20DI Type 2
70J9X P10_SR20DI Type 2
70JXX P10_SR20DI Type 2
60UXX Q45_VH45DE_90 Type 2
62UXX Q45_VH45DE_90 Type 2
65EXX U12_KA24E Type 2
95EXX U12_KA24E Type 2
71VXX Y31_VG20DE Type 2
1P1XX Y32_VH41 Type 2
35JXX Y60_TB42E Type 2
30PXX Z32_VG30 Type 2
31PXX Z32_VG30 Type 2
37PXX Z32_VG30 Type 2
40PXX Z32_VG30 Type 2
41PXX Z32_VG30 Type 2
46PXX Z32_VG30 Type 2
47PXX Z32_VG30 Type 2
48PXX Z32_VG30 Type 2
64YXX B13_SR20_91_92 Type 3
67YXX B13_SR20_91_92 Type 3
71YXX B13_SR20_93 Type 3
70YXX B13_SR20_93 Type 3
78CXX B13_SR20_93 Type 3
97EXX J30_VE30DE Type 3
58YXX N14_SR18DE Type 3
68CXX N14_SR20DE_91_92 Type 3
1N96X N15_SR20DE_EARLY Type 3
1N97X N15_SR20DE_EARLY Type 3
62JXX P10_SR20DE_91_92 Type 3
70J0X P10_SR20DE_93 Type 3
70J1X P10_SR20DE_93 Type 3
0J26X P10_SR20DE_93 Type 3
0J27X P10_SR20DE_93 Type 3
78NXX PW10_SR20 Type 3
53FXX S13_KA24DE Type 3
54FXX S13_KA24DE Type 3
59FXX S13_KA24DE Type 3
50FXX S13_SR20 Type 3
54CXX S13_SR20 Type 3 RNN14
69CXX S13_SR20 Type 3 RNN14
4E6XX S13_SR20 Type 3 U13
1E0XX S13_SR20 Type 3 U13
52FXX S13_SR20DE Type 3
69FXX S14_SR20 Type 3
74FXX S14_SR20 Type 3
75FXX S14_SR20 Type 3
79EXX U12_SR20DET Type 3
95NXX W10_SR20 Type 4 Adaptor A
45PXX Z32_VG30_LATE Type 3
51PXX Z32_VG30_LATE Type 3
53PXX Z32_VG30_LATE Type 3
63UXX Q45_VH45DE_94 Type 3 (TBD)
67UXX Q45_VH45DE_94 Type 3 (TBD)
68UXX Q45_VH45DE_94 Type 3 (TBD)
1N4XX N15_SR20DE_LATE Type 4 Adaptor A
0M2XX B14_GA16DE Type 4 Adaptor B
0M7XX B14_SR20DE_95_96 Type 4 Adaptor B
1M8XX B14_SR20DE_95_96 Type 4 Adaptor B
AA5XX ER34_RB25 Type 4 Adaptor C
0J2XX G20_P10_SR20DE Type 4 Adaptor B
0J6XX G20_P10_SR20DE Type 4 Adaptor B
1N90X N15A_GA16 Type 4 Adaptor B
1N91X N15A_GA16 Type 4 Adaptor B
83JXX P10_SR20DE_94_95 Type 4 Adaptor A
3J5XX P11_SR20 Type 4 Adaptor A (Bosch ECU)
3J8XX P11_SR20 Type 4 Adaptor A (Bosch ECU)
60FXX S13_SR20 Type 4 Adaptor A (Late 180SX)
70FXX S14_KA24DE Type 4 Adaptor B
80FXX S14_SR20 Type 4 Adaptor A
82FXX S14_SR20 Type 4 Adaptor A
83FXX S14_SR20 Type 4 Adaptor A
91FXX S15_SR20 Type 4 Adaptor A
93FXX S15_SR20 Type 4 Adaptor A
3E1XX U13_KA24DE Type 4 Adaptor B
4E8XX U13_KA24DE Type 4 Adaptor B
0V8XX WC34_RB25 Type 4 Adaptor C
5P7XX Y33_VQ30 Type 4 Adaptor B
4P2XX Y33_VQ30 Type 4 Adaptor B
74BXX K11_CG10_LATE Type 4 Adaptor A
1U2XX K11_CG10_LATE Type 4 Adaptor A
49UXX A32_VG30 Type 4 (OBDII TBD) Adaptor B
54UXX A32_VG30 Type 4 (OBDII TBD) Adaptor B
N/A B14_SR20DE_96 Type 4 (OBDII TBD) Adaptor C
72FXX S14_KA24DE Type 4 (OBDII TBD) Adaptor B
N/A Z32_VG30_96 Type 4 (OBDII TBD) Adaptor A
0U0XX K11_CG10 Type 5 (TBD)
44BXX K11_CG10 Type 5 (TBD)
99BXX K11_CG10 Type 5 (TBD)
65FXX S14_SR20DE Type 5 (TBD)
24UXX BNCR33_RB25 Use BNR32 ECU Use BNR32 O2 sensors
13UXX ECR33_RB25 Use Z32 ECU See RB25DET Rewiring document
21UXX ECR33_RB25 Use Z32 ECU See RB25DET Rewiring document
28UXX ECR33_RB25 Use Z32 ECU See RB25DET Rewiring document
erikscimitardemon
Re: Nissan ECU part numbers
Post by erikscimitardemon » Mon Dec 16, 2013 11:48 am
Very usefull info Jim.
I made it a sticky :D
Erik Hofman
http://www.scimitar.demon.nl
