Small Sports Detectives - SST/Sabre Spec Differences
sabre1800ti
Re: Small Sports Detectives - SST/Sabre Spec Differences
Post by sabre1800ti » Wed Oct 15, 2014 10:54 am
My Mk1 1800 Sabre has the seats that seem to be the SST prototype, also have no pockets on the back.
Doug Black
Ex-Factory 1993 Scimitar Sabre 1800Ti Mk 1
Has thanked: 61 times
Been thanked: 103 times
Post by reliant-reviver » Wed Oct 15, 2014 1:23 pm
Doug, checked some pics and your car is as per the norm with "pleated" for want of a better term (AJL, your the trim man about town, enlighten us?) black leather.
Actually, scratch the part about plain faced leather on the pototype SST. Appears that is not the case. I recall one of the very first SSTs having plain faced leather, but can't for the life of me find it. Maybe I made it up.....
Anyway, shall edit the post on previous page.
sabre1800ti
Post by sabre1800ti » Wed Oct 15, 2014 1:31 pm
Ooops, you're right. :oops: (Age related memory failure :) ).
But definitely no rear pockets .
Doug Black
Post by reliant-reviver » Wed Oct 15, 2014 1:33 pm
I think by that point, Reliant, in relation to the whole Small Sports affair, were well out of pocket....... ba-dum-tshh
Has thanked: 113 times
Been thanked: 795 times
Post by scimjim » Wed Sep 02, 2015 10:45 pm
Dave Poole has just sent me a load of Service Bulletins from 1985-1989 which answer a lot of questions regarding exact chassis numbers when things were introduced.
so.......
door drain plates (the two bits of metal over the rubber seal at sill level) - from SCD210271FF000417 with retrospective fitting to earlier cars
type 9 reverse light switch - 210274FB000497 no part number change/directly interchangeable
door cards changed (type 1 - type 2) - 210283FG000563 with retrospective fitting to earlier cars
Diff front mounting bolt spacer - 210270FH000610 with retrospective fitting to earlier cars
Light switch incorrect wiring and rad fan/heater fan & wash/wipe fuse rating change - 210281FK000687 with mandatory conversion to earlier cars
Adjustable link between interior door handle and lock mechanism - 210271FK000696 with retrospective fitting to earlier cars
Interscreen 200 paint underbonnet (radio suppression paint) - 210274FL000726 with retrospective fitting to earlier cars
fuel tank vent change (moved to LHS of tank) and securing bracket for filler neck - 210271GA000733 with retrospective fitting to earlier cars
delete electric dipstick - 210283GA000737
diff cradle front mount, stiffener plate and rubber bush - 210181GD000784 with retrospective fitting to earlier cars
increased dia of rad to header tank bleed hose - 210283GD000795 with retrospective fitting to earlier cars
delrin plastic bush in place of phosphor bronze bush in the headlamp cradle link - 210283GD000800 with retrospective fitting to earlier cars
single wiper - 210281GE000810
fuel tank roll over vent and non-vented cap - 210571GF000882
revised 1600 alternator pulley/water pump/front cover/crank pulley/cooling pipes - 210770GJ000951
revised door A post finisher trim - 210471HA000999 with retrospective fitting to earlier cars if needed
Revised Ti loom with additional coil supply relay - 210570HL0001205
ABS trim under door pull on type 1/2 door cards prior to 21087?JD001310
door cards (type 2 to type 3) - 21087?JD001311 approx! with retrospective fitting to earlier cars
tonneau cover available - 1989
Mateybass
Post by Mateybass » Thu Sep 03, 2015 12:27 am
Are there any for post 89?
1991 Reliant Scimitar SST 1400 number 39 - Skippy's Facebook Page
1999 Subaru Forester S-Turbo Auto (LT)
RSSOC member no. 6883
Post by scimjim » Thu Sep 03, 2015 6:29 am
'fraid not.
Post by scimjim » Mon Feb 01, 2016 12:28 am
I knew the 1400 SST was a rare beast but still did a double take when I read in Slice 267 that there were only five :shock:
The database shows at least ten :-)
Mateybass
Post by Mateybass » Mon Feb 01, 2016 2:49 am
scimjim wrote:I knew the 1400 SST was a rare beast but still did a double take when I read in Slice 267 that there were only five :shock:
Yeah, I read that and thought that's a bit wrong...
I thought we'd collectively worked it out to eleven a while ago because I remember posting that there was over 25% of factory output in Lincolnshire alone... Me, my brother and a bloke not far from Mablethorpe makes three 1400 SST... two blue and one red. :shock:
Post by greeny » Mon Feb 01, 2016 8:23 am
And there's 2 in Cheshire one blue ours and one in white Steve Fs
Post by scimjim » Mon Feb 01, 2016 8:31 am
Yep - I was being a bit vague because at least one is dressed as a Sabre and two (including Steve Feay's) appear just inside Sabre production (perhaps we should move the SST line down to include those and accept that 2045 is either a converted SST or a concurrent production car)?
Which is a long way of saying I think there's 13 x CVH 1400s that look like a "conventional" SST?
Been thanked: 514 times
Post by philhoward » Mon Feb 01, 2016 8:36 am
"monobody cars without arches"?
Running by the premise that Reliant changed the name that often...to me, at least, if it's a monobody and had arches, it's a Sabre. No arches, then an SST. Bit too simplistic?
Post by scimjim » Mon Feb 01, 2016 8:55 am
Works for 99% :-)
Post by philhoward » Mon Feb 01, 2016 9:22 am
Close enough then ;)
Post by greeny » Mon Feb 01, 2016 10:50 am
You have to move reliants consistency!!
