Britax Sunway Folding Roof installation Guide.
JoeySully
Has thanked: 39 times
Been thanked: 24 times
Post by JoeySully » Thu Apr 21, 2011 10:34 am
Found this on http://www.slidingragtops.com/
May be of use to someone with Britax sunroof fitted. Now all I need is a similar guide to the Webasto version :roll:
I don't know if this is more the Mini type sunroof from the 90's rather than one typically fitted to Scimitars of the 60's 70's?
David Balkwill
Re: Britax Sunway Folding Roof installation Guide.
Post by David Balkwill » Wed Nov 05, 2014 9:32 am
Hello from an MGB owner. I just read through the sunroof instructions on this page and thought you might be interested in the instructions for the earlier Britax Weathershield roofs. I renovate them, making new inner and outer covers, glassfibre rails to replace the rusted steel ones, new plastic sliders, mouldings to go around the handles, and tinted perspex wind deflectors.
Do send me a message if you need any help with yours.
David in sunny France.
The files are in a Dropbox here together with photos of some of the roofs I've done.
https://www.dropbox.com/sh/k4f5avz1pfuc ... ZWEoa?dl=0
Here's a description of the procedure if you want to do your own.
Sunroof cover instructions.pdf
(47.64 KiB) Downloaded 360 times
