Fitting sliding rear brake slave cylinders
Has thanked: 122 times
Been thanked: 908 times
Post by scimjim » Fri May 25, 2018 4:51 pm
philhoward wrote:If anyone has a foolproof and quick way of fitting the cylinder and clips, I'm all ears. Now done, but not a job I'd like to repeat in a hurry!
toomanysabres wrote:
Wed Jul 10, 2013 11:38 am
After consulting oracles far and wide (well at least the other side of the Dartford tunnel) I have the foolproof way and you will wonder what all the fuss was about.
Its the answer to life, the universe and everything about fixing the rear cylinders.
Refer to the diagram in either book its the same drawing (mine is the RSSOC Autobooks fig 11:3 p 110)
Assemble in the following order.
1) Insert cylinder 6 on its own into the backplate.
2) Slide on U clip 13 direction as shown in the manual.
3) Slide on U clip 11 BUT IN THE OPPOSITE DIRECTION TO THE MANUAL (ie same as 13) with the curved side towards the backplate.
The cylinder is now a sloppy fit in the backplate.
4) Insert handbrake lever 9 there will be enough clearance to fiddle it into place in its pocket and trapped between cylinder and backplate.
5) Insert flat clip 12 between 11 & 13 ALSO IN THE OPPOSITE DIRECTION TO THE MANUAL and get the notches locked into the tips of the adjacent clip.
6) Fit the rubber boot 10 ensuring a snug fit of the thin sides around the clip.
7) Go and have a cup of tea/beer. Simples innit.
philhoward wrote:
Wed Jul 10, 2013 11:42 am
Easy when you know how...
I fitted the "matching pair" of clips with the double notches first, then the handbrake lever, then the outer clip. Second one went on much easier and quicker than the first! Left the boot off the second one first of all. Nothing a knife and superglue couldn't fix though.
Also found it much easier to fit the pipes first, then clip it to the backplate...
Wed Jul 10, 2013 11:54 am
I guess previous gorillas have over bent clip 13. While its in the sloppy fit position, agreed, slip the boot on and start the unions into their threads. When clipped in check it slides up & down the slot ok and tighten the unions
philhoward wrote:
Wed Jul 10, 2013 12:10 pm
New clip kit from GW...gorilla fitting it though ;)
Edit:- Original part number if you can find a 'NOS' is Girling SP2862
