Rebel 750
For other Reliants.
turbster
Has thanked: 65 times
Been thanked: 56 times
Rebel 750
Post by turbster » Tue Oct 01, 2019 7:43 pm
I’ve bought myself a Rebel and the unusual east west mounting master cylinder has a scored bore. Anyone know where I can get one, or am I going to have to convert it to the common north/south type?
LRP 335E SE4a
XRF 976H SE5
www.gtevolution.co.uk
Has thanked: 182 times
Been thanked: 98 times
Rebel 750 master cylinder
Post by efi_sprintgte » Tue Oct 01, 2019 8:26 pm
No idea on the M/C but I’ve always wanted a rebel :mrgreen:
Has thanked: 39 times
Been thanked: 141 times
Post by Oaksey » Tue Oct 01, 2019 8:27 pm
I gave up and converted mine
1973 Beige Se5a Overdrive
2005 Honda S2000
2014 BMW 330d xDrive
TrevorG
Has thanked: 26 times
Been thanked: 32 times
Post by TrevorG » Tue Oct 01, 2019 8:35 pm
Pity it's not the 1600 prototype :mrgreen: that sounded interesting.
Wonder if the kitten gear would be an easy replacement?
turbster
Post by turbster » Tue Oct 01, 2019 9:11 pm
Everybody loves a Rebel! Just need some panels to make it a van now
LRP 335E SE4a
XRF 976H SE5
turbster
Post by turbster » Tue Oct 01, 2019 9:12 pm
Looks like I’ll be doing the same Josh!
LRP 335E SE4a
XRF 976H SE5
turbster
Already thought about recreating that one.. another day maybe!?
LRP 335E SE4a
XRF 976H SE5
Post by efi_sprintgte » Tue Oct 01, 2019 9:50 pm
Didn’t Joe on here have a thread mentioning panels for van windows? I might be going mad...
turbster
Post by turbster » Tue Oct 01, 2019 9:56 pm
No I remembered that too, meant to message him so cheers 👍
LRP 335E SE4a
XRF 976H SE5
Post by efi_sprintgte » Tue Oct 01, 2019 9:57 pm
Joe. wrote:
Mon Jan 30, 2012 5:50 pm
While on the Isle of wight we took advantage of the use of Dave's bosses' workshop to create some moulds for some new side panels. Creation of moulds is much easier with access to a decent workshop with space to work and the use of bench saws etc!
I've not got many photos of the woodwork. Essentially they were made from pine strips screwed to a sheet of hardboard. The wood underneath gives the hardboard a slight curve to matches the slight curve in the body of the van. The corners are made of body filler as it was quicker than making them out of wood. If you were making a mould to be reused many times it would pay to do these in wood too.
The moulds were fared in filler, creating a radius and also filling in screw holes and imperfections in the wood.
Corner section closeup
Filled sections were then sanded down and the moulds were clamped to the bench to prevent distortion.
The moulds were then coated with 5 coats of release wax this is the minimum needed, ten coats is a good target to get the best results.
The wax was then buffed with a fresh cloth.
The moulds were ready for Gelcoat, given the cold temperature in the workshop we were using a 2% mix of hardener. Resin was weighed to calculate hardener mixes accurately.
Gelcoat was then applied to the moulds
These were then left under the heat lamp for a few hours to until touch dry
the lay up could then begin, each mould used 2 sheets of medium density csm. any additional thickness will be added when the panels are fitted.
resin was applied by brush and laminating rollers were used to ensure there were no air pockets.
Rolling out
With 2 Layers applied to each mould they were left under the heat lamp until the resin had properly gone off.
Waiting for release:
Panels out:
In a couple of places the mould filler is stuck to the gel but will sand off nicely.
A trial fitting,
Hoping to be in a position to fit them later this month, :D
Post by efi_sprintgte » Tue Oct 01, 2019 9:58 pm
Edit, found it!
Joe. wrote:
Sat Mar 17, 2012 12:55 pm
The van now has side panels! :)
We spent the last 2 days putting the panels in and giving a rough coat of paint generally very pleased with the result, the fine fettling on the paintwork will be done in the future when the whole van will be repainted.
In other news the van is now tax exempt which took a while to sort the paperwork out with the dvla.
turbster
Post by turbster » Tue Oct 01, 2019 10:19 pm
Just put it on insurance database and it is a commercial anyway.. must’ve had the sliding windows added later then.
LRP 335E SE4a
XRF 976H SE5
turbster
Post by turbster » Wed Oct 02, 2019 7:09 pm
That’s the master cylinder issue sorted.. still needs a new pipe making up, then I can get them bled and working 8)
I’m starting to like this little fella way too much :lol:
LRP 335E SE4a
XRF 976H SE5
td99
Has thanked: 17 times
Been thanked: 33 times
Post by td99 » Wed Oct 02, 2019 7:27 pm
Just don't paint it orange and race it!
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Post by efi_sprintgte » Wed Oct 02, 2019 7:31 pm
I disagree entirely :lol:
